Results 1 to 12 of 12
Thread: Hints of blockage?
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Default Hints of blockage?
    Well, like the title says, what signs or hints are there that the radiator has blocked?
    Went for a 15 minute drive, got it to operating temp, had it turned off for an hour then went for a 5-10 minute drive, felt the radiator cap and it was cold. Then I opened it slightly to de-pressurize it and it started to warm up. Hmm whats happening here?
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    sounds like thermostate cactus.
    does it actually overheat?? maybe the thermostate is of a higher opening temp.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    GOTMYN's Avatar
    GOTMYN is offline Stab it and Steer...
    Whippled 5.7, VE SV6, GU Patrol 3.0DI
    Sep 2006
    Mornington, Vic
    Dead thermostat Mate,
    Take it out (inside thermostat housing) and do it all again, if it still does it, then yep blocked Rad, otherwise Boil Kettle and fill cup with Boiling water, drop thermostat in, if it opens, it's OK.......if it stays shut It's Kaktus!!
    Good Luck :-)
    If I'm not pulling Toyota's out of the Bush, I'm pulling 12's in the Sig :-)
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Thermostat is about 3 months old.
    Doesnt overheat.
    My Commy
    Discuss.
    GOTMYN's Avatar
    Sep 2006
    Mornington, Vic
    Quote Originally Posted by Wombles View Post
    Doesnt overheat.
    Thermostats are crap these days unless you buy genuine,
    3 months can be a good innings for one of the Jap made products...
    Otherwise, you water pump isn't doing it's job....
    Take rad out, and reverse flush it,
    I normally use a acid based cleaner, fill rad with a mix of this and water for 10 mins, the reverse flush with high pressure, Like a fire hose :-)
    Worked for me in the past.................................
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Just a quick query, if the car doesnt overheat, and the coolant isnt rusty, what is the problem?
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Getting the car to run it's best and not have problem like this happening.
    Just thought of this because I drained the system, expecting heaps of coolant to come out, not much did. Like 3 litres or so. So im just thinking that it might not be too good for the car.
    My Commy
    Discuss.
    Jan 2008
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Nope, I was just doing what the book said. Haha. Thats probably why it failed.
    My Commy
    Discuss.
    Jan 2008
    Yeah try taking the thermostat out when you drain it, otherwise you are only draining the radiator
    vs commodore
    Oct 2009
    Tamworth NSW
    If you drop the bottom hose,it will drain the radiator and most of the block,to completely drain the block the knock sensors have to be removed.But the thermostat wont stop most of the block draining.Is the car overheating at all?
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Not really. It just gets to quarter on the guage and rarely hits half most of the time.
    My Commy
    Discuss.
  1. Holden: Hints of Torana
    By CSP in forum News/Updates
    Last Post: 11-02-2009, 11:04 AM
  2. oil blockage
    By Nicky t in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2007, 03:12 PM
  3. HID Conversion on VT Hints.......
    By lil_oneblue in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-11-2007, 11:29 AM
  4. Replacing Tensioner...any hints?
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2007, 10:41 PM
  5. Heater Core Blockage!
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-05-2005, 12:59 PM
