Results 1 to 6 of 6
Thread: whiney noise coming from steering ( not ps fluid )
    VS executive
    Jun 2009
    Default whiney noise coming from steering ( not ps fluid )
    i have a whiney noise coming from somewhere inside the car around the steering column , it only does it when the car is cold and goes away after its warmed up , ive posted this before and someone suggested it could be the `boot` or something ( i dont know what that is ) and to get under there and lubricate it as best as possible.
    well i have some wd40 if that adequate now i just need too know what too look for, was wondering if anyone could post a pic if you can get too it with a camera or has any other suggestions.
    (couldnt find the thread with the ffs search button so reposting)
    edit: i should add that it only does it when im turning the wheel ofcourse.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    have you got a enough power steering fluid, ive seen sometimes a whiny sound when the fluid also is old and needs to be replaced.
    VS executive
    Jun 2009
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    there is bearings where the steering wheel rod goes through the firewall, give it a spray with wd40, down under the pedals.
    VS executive
    Jun 2009
    vs commodore
    Oct 2009
    Tamworth NSW
    Yeah ,these are known for making that noise,It sounds similar to a P/S pump that is cactus.Like The1 says, spray the area where the steering shaft goes through the firewall with wd,this bush or bearing makes a horrible noise(groaning sound) and is so easily fixed with wd 40.I spray it from the engine side of the steering shaft straight in, where the shaft goes into the firewall,You sort of have to get it to spray upwards into it, and this is usually enough to fix it.Also I've seen someone take their car to get this noise"fixed".The place where they went to changed the P/S pumps ,rack etc and the noise was still been there.A complete waste of money.
  1. Clicking noise coming from outside of car
    By stocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2009, 04:17 PM
  2. whiney noise coming from steeringwheel ( not power steering )
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2009, 07:58 PM
  3. Noise coming from engine bay
    By kizza_VL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2009, 06:52 PM
  4. WTF is that noise and why is the light coming on?
    By gupatrol in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:59 PM
  5. whiney noise coming from back of vn
    By mickah in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2005, 09:32 PM
