Leaking Injector/s
I think I have one or more leaking injectors. When I stop the car and then later start it up, it cranks and cranks then splutters into life. Black smoke comes out the exhaust which is obviously un-burnt fuel that has leaked into the piston or intake manifold. The injector rack is still under pressure after stopping. Would I have to take out each injector and if so how do you test them for a seal or would the damage be obvious? Are they hard to get out without damaging them?
After the car has be idle for a few days, it starts first crank. The car runs fine when running.
When everything's coming your way, you're in the wrong lane.
