Results 1 to 16 of 16
Thread: VS Commodore - Slight Mods?
    HSV VT MANTA
    Jan 2010
    Default VS Commodore - Slight Mods?
    Heey guys. Recently joined here, have been browsing a bit.
    I have a few quick questions, which hopefully shouldn't be too much of a pain :P.
    I have recently bought a VSII commodore, Auto, 150,000 ks. etc etc. As i'm on my P plates, i obviously can't do any modifications to the car.
    But, what would i need to do an Auto to manual conversion? I'm assuming the RTA wouldn't let me do it as i'm on P plates and it'll require an engineers certificate. (Obviously i'll need a gearbox clutch etc etc etc)
    Also, it states in the P Plate legislation that if a model comes with for example a 3.8L ecotec V6 i can swap to another 3.8L ecotec 6.. So would it be legal to take an ecotec block out of a VY commodore and throw it in mine?.
    Cheers, Rodd.
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by Mr.38L View Post
    This is for VN-VR, but you will still need all the parts listed.
    The complete Vn-Vr Manual Conversion Guide.
    If you use a T5 it will all be legit, and you shouldn't need an engineers cert because it came from factory like that. Get a wreck, that would be the easiest.
    I can't see why there would be a problem with swapping motors, they would be exactly the same.
    HSV VT MANTA
    Jan 2010
    Quote Originally Posted by _R_J_K_ View Post
    Only part that would be different is that the VY block has 152kw and the VS only has 147.. but then again.. i think the newer VY block would be more economical anyway.
    VS Berlina 3.8
    Dec 2008
    There is no difference between the blocks, or any other part of the engine. The only difference that I've read about is that you will have to drill out a hole for an extra temperature sensor (one to the ECU and one to the temp gauge). The extra 5kw you speak of comes from the different tune used in the VY.
    VP Exec
    Jun 2005
    There should be no issue with the rego. authority (check with the one which applies to be certain) in any state where the manual conversion uses the factory parts. There shouldn't be any need for an engineering report as there is no engineering required - it would be classified as an owner certified conversion in Vic. or NSW and I think ACT.
    Notifying the rego. authority of the change will be required.
    A VS II manual would have used the Getrag 'box from the factory. A manual conversion using the BW T5 should also be OK.
    There are some differences between the exhaust (Y-pipe, cat. location) between VS SI and SII. It's possible that may create some clearance issues if using the T5 with the SII exhaust.
    The Getrag 'box uses a hydraulic clutch which means a different pedal box (to T5) and the clutch master cyl. will be needed.
    There are some minor differences between the VS SI, VS SII, VT, VX and VY Ecotecs. Some of these include the presence of a fuel canister purge solenoid from VSII-, EGR with VT-, minor changes to the inlet manifold and PCV valve VX-, different injectors across the models.
    Strictly speaking, if a later model engine that meets a tougher emissions ADR is fitted to an earlier car, even if ostensibly similar, all the ancilliaries have to fitted with it in order to maintain the emissions compliance. This includes the PCM. In practice you can usually get away with just swapping the engines and hoping that no one can tell the difference.
    HSV VT MANTA
    Jan 2010
    Thanks for all the help and advice guys!. It's really appreciated!.
    My best bet would be a wrecker for the gear box etc yeah?
    Also, another quick question, If i wanted to add power windows to my car, i could just goto a wreckers and get a complete system? I'd probably need a new BCM as well tho huh?
    VS Executive 3.8 Eco
    Oct 2005
    try not to go to a wrecker try and find someone off here whos selling the manual conversion, they tend to be a little bit more trustworthy, they also come up for sale quite a bit here. also i understand that your not allowed to do any mods because your on your p's that will increase the performace of the engine but im sure you can still do things such as an exhaust and maybe highflow filter with a cai. dont quote me though on these. diff gears is another way to get a lil more out of your car without effecting the power output in any way possible
    HSV VT MANTA
    Jan 2010
    VS Berlina 3.8
    Dec 2008
    Doubt it. Have a search around, there is a chart which outlines what features were included for each level of BCM.
    Subaru Forester GT, ET Turbo Pulsar, VS 5.0L Ute
    Oct 2009
    Frankston, Victoria
    Quote Originally Posted by speed_freak View Post
    Doing this to your car will increase the performance mate
    HSV VT MANTA
    Jan 2010
    Thought so. Even if i was getting a CAI, it'd probably be a hsv one of some sort. Might upgrade the brakes too.. take a VT setup system and put it on.
    Where am i best off looking for a getrag box?
    VS Berlina 3.8
    Dec 2008
    Why HSV? Don't bother with the SS Inductions or HSV CAI's, they are just an overpriced waste of money. Pick up the Super 6 CAI for about $70 (with duct) from a Holden dealer.
    Your probably best off looking for a T5 setup. Parts for the Getrag are horrendously expensive because of the dual mass flywheel and the hydraulic clutch. Go for a T5 setup.
    The easiest way to do the conversion will be to pick up a wreck. That way you have all the parts you need and won't need to buy all the parts individually at inflated prices.
    HSV VT MANTA
    Jan 2010
    Mine's a series 2.. it comes with a getrag box.. how hard is it gunna be to do a T5 conversion?
    HSV VT MANTA
    Jan 2010
  15. #15
    VS Berlina 3.8
    Dec 2008
    T5 = easier.
    Yes, it cam from factory with a Getrag box, but there's nothing stopping you from doing the T5 with parts from an S1 VS. T5 has a cable clutch, so there's no messing around with the hydraulic stuff that the Getrag employs. If you buy a wreck, you will have all the parts you need. Sometimes there are complete conversion kits on eBay that include all the parts.
    The guide that I posted before (The complete Vn-Vr Manual Conversion Guide.) outlines a T5 conversion. It will be pretty much the same for the VS.
  16. #16
    HSV VT MANTA
    Jan 2010
    Well, am i going to have any problems with Rego? I don't wanna have to get it engineered so.. I thought that if it was a series 2 it had to have a series 2 gearbox in it?, not the model in general (VS).
  1. Mods For Commodore
    By thomasr in forum V6 Development And Modification
    Last Post: 09-12-2009, 01:59 PM
  2. vs commodore mods?
    By msina1 in forum General
    Last Post: 04-04-2009, 02:39 AM
  3. Commodore Cup mods?
    By ow2839 in forum V8 Development and Modification
    Last Post: 30-09-2007, 11:30 PM
  4. vk commodore mods
    By Mazzone_Child in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-09-2005, 08:50 PM
  5. Wow, Fuel Economy is mad after slight mods.
    By Bucket in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-06-2005, 08:29 AM
