Results 1 to 20 of 20
Thread: aftermarket alternator?
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Default aftermarket alternator?
    So. the alternator in my VR blew up yesterday... smoke and all. Changed over to a reco one I got from the wreckers, and it's working good now.
    But a mate was saying it could have gone because I'm running an amp and a sub and I should get a more powerful alternator.
    If i keep running my new alternator will it just blow up? what alternator should I get if i do need a better one?
    vs commodore
    Oct 2009
    Tamworth NSW
    You can get higher amperage alternators,depending on how much you want to spend on one.The standard one is around 100 amps.Im not sure exactly how much higher amperage than the standard one you can get,but last I heard,they were heaps expensive.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    was afraid of that. but will the reco one just go early cos it's being pushed harder? the one that blew was most likely the original so pretty old.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    What amp are you running? I'm almost willing to bet my car its not going to be powerful enough to cause any issues
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by Philthy View Post
    IX404 with a 15"" sub (i think lol)
    vs commodore
    Oct 2009
    Tamworth NSW
    Some big stereo systems and some driving lights can load up the alternator enough to make it work harder that it has to.Thats when you want a higher amperage alternator.The alternators these days have a huge load on them anyway.Years ago,you could drive around all day with no alternator before the battery went flat.These days you would be lucky to get 15 minutes out of a fully charged battery,so they do a lot of work.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    vs commodore
    Oct 2009
    Tamworth NSW
    Yours was probably just old.With most cars,the standard alternator will do just fine.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    standard alternators are 85amps, but you can get police spec 120 amp ones.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Philthy's Avatar
    Aug 2005
    With that amp there's no way in hell its straining your electrical system unless you have a million hektik neons hooked up as well.
    Sounds to me like it was just old
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Highly doubt your amp is an issue. Jst sounds like you had a winding break down. It happens somtimes, jst unlucky for you i would say. If it continues to happen into the future then you may need to asses whats happenin but i would be suprised ifit happened again.
    Reaper
  15. #15
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Don't forgot everything will get the extra juice as well so you have to make sure they can handle it.
  16. #16
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by wraith View Post
    what do you mean?
    just a thought, is it worth getting my old alternator re-coed and selling it? i think it wasn't too happy about the 44 degree heat we had the other day.
  17. #17
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    I mean if you went for some uber high amperage alternator could everything handle it. I think I have a 120 amp alternator in mine and assuming amp is properly grounded and installed with the right guage wire you won't have issues with straining the alternator unless you have something crazy like 5 amps, neons etc.
  18. #18
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Oh as a side note. Without alternator VR's last 60 k max with lights on and fully charged new battery. Found that out the hard way.
  19. #19
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    ha thanks, good to know. mine blew up pretty bad, the car wouldn't drive til I replaced it.
  20. #20
    VS V8 Berlina Wagon
    Jul 2006
    i had to get a new one on a drive to syd from melb, we got to gundagai and the battery light came on, drove till the start of the M7 and every thing just died, i had the UHF running and being used, the radio going and a portable fridge.
  1. When should i put my aftermarket ECU in?
    By Dinwoodie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2009, 03:15 PM
  2. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  3. How to tell if i got an aftermarket CAM?
    By Chalky01 in forum General
    Last Post: 27-01-2009, 05:49 PM
  4. VE sv6 or ss with aftermarket cd/mp3
    By ashtray1 in forum Car Audio
    Last Post: 13-01-2009, 11:10 PM
  5. Aftermarket MAF
    By VZ_SV6_NZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-07-2008, 04:26 PM
