Results 1 to 5 of 5
Thread: Power windows in Vr Executive?
    94 Vr Executive
    Oct 2009
    Central Coast
    Question Power windows in Vr Executive?
    Hey Guys, I recently bought the power window regulators, all switches, each doors wiring loom and door trims for my vr executive. I read a few posts on here to try and figure out what else i need and i am still a bit confused. I checked to see if my car has the wiring for the power windows and i found that i have the power window looms in the front doors but not the back and that i dont have the main window dash loom. So far i think i need the main window dash loom (Is this its own loom or part of another? and where does it all go to?) and im not sure but i think i am going to have to buy a mid level bcm and matching key head so i can have all 4 power windows (correct me if im wrong but i think the low bcm which is in my car controls front power windows only and the mid control all 4 power windows?). If i do need the mid level bcm is there anything else i would have to do to get it all working? sorry if someone has gone over this before but i searched and searched and am stuck on these few things. if anyone can help me out that would be awesome.
    Thanks guys
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    There is a great "how-to" in that section on this subject by hdt_aero and I've copied it below for your convenience. Not sure if it mention which BCM but I remember seeing a diagram which showed what each BCM was capable of and I think you are correct. Anyways, have a look at this article as it will provide just about all you need. Good Luck.
    How to install Power Windows
    94 Vr Executive
    Oct 2009
    Central Coast
    Quote Originally Posted by hako View Post
    Ohh yehh ok now im starting to get it lol. So i basically need the vn calais module, the main window dash loom and do i need relays or fuses or is it part of the module? and does the main window dash loom have to be from a vn or does all the vr wiring connect up to the module? sorry if im sounding stupid just wanna make sure i have everything lol and thanks for the quick reply.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've never done this conversion so everything I know about it is secondhand......the loom you really need is located under the radio and accessed by pulling the centre console...if it's not there you are needing to do a lot of work (from what I've read). I don't think you specifically need a VN Calais BCM....you need a mid series VR BCM. The "how-to" was written for VN.
    This has been covered many times before.....so I'd vary my search engine questions and spend a few hours doing that - it will save you heaps of hassles.
    94 Vr Executive
    Oct 2009
    Central Coast
    Thumbs up
    Righto mate, yeh had a look for that main loom and im almost certain i dont have it but ill have another look. That VN calais module there talking about isn't a BCM it just a module that the VN's and VP's used (might be just VN's) that controls the power windows. But yeh im pretty sure i now what i need to do now so thanks alot for ya help mate
  1. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  2. Power windows in vy executive??
    By jwarran69 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-01-2009, 11:58 AM
  3. power windows in executive vs
    By slappa. in forum Electrical Wiring / Questions
    Last Post: 26-05-2006, 08:28 PM
  4. Putting Electric windows in VS Executive???
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-05-2006, 10:43 PM
  5. VX Executive, Power Windows fitting ?
    By mjfs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2005, 09:03 PM
