Results 1 to 8 of 8
Thread: Replacing sun sensor in a VR Calais
    VR Calais
    Aug 2009
    Default Replacing sun sensor in a VR Calais
    The "X" showed up in my climate control display today, but the aircon seemed to be working OK.
    However, according to diagnostics [as per VS Commodore climate control diagnostic check the sun sensor has failed (the little "button" in the middle of the dash).
    Does this mean the dash has to be removed, or is there a trick to getting the liddle f***er out???
    Thanks
    308commodore's Avatar
    308commodore is offline 308 commodore
    308 VK CALAIS
    Mar 2005
    camira, queensland
    The " little button " is only clipped into place and there is a connection for the wiring as well. I've used a little blade screwdriver to pop it out and unclip the wiring connector and replaced it that way.
    cheers...
    Go the allmighty 308 if the bloody thing will run!!!
    VR Calais
    Aug 2009
    308 VK CALAIS
    Mar 2005
    camira, queensland
    Quote Originally Posted by pecksterism99 View Post
    Thanks heaps 308!
    no probs mate...
    VR Calais
    Aug 2009
    Default is there a plug on the end of the sun sensor cable?
    Hi - Took a while to get around to this as it started working OK again. But now it's very intermittent.
    I pulled up the sun sensor OK ... wires were fairly tight but with a firmish pull got about 10cm out ... but still no sign of a plug ...
    Just wondering how long the leads are from the sensor, and if there is a plug?
    Last thing I want to do is break the wires and have to remove the dash!
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    nothing wrong with breaking wires, as long as you join and insulate them properly again. No dodgy twist and tape scenarios, poorly done solder joints, or those crappy clip connectors. Only use quality crimp connectors with the double sleeve with the correct ratchet crimpers, or proper quality solder joints are better.
    Reaper
    VR Calais
    Aug 2009
    VR Calais
    Aug 2009
    Just a follow up in case anyone has same issue. Finally got to the sun sensor plug simply by taking out the two screws in the demister trim, and levering it up with a flat blade screw driver from the clip on the RHS. I could not pull the plug fully apart, but pushing it hard together seemed to do the trick. Must've been a bad connection in the plug. Problem hasn't recurred after few thousand kms, so it must be fixed!
  1. Replacing Oil Pressure Sensor
    By tepaus in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-11-2011, 09:46 PM
  2. Replacing Sun Sensor?
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2007, 10:22 PM
  3. Replacing 02 Sensor
    By nathanashton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2007, 04:16 PM
  4. Replacing the o2 Sensor????
    By CustomVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2006, 08:47 PM
  5. Replacing The O2 Sensor
    By Tony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2004, 10:19 PM
