Results 1 to 14 of 14
Thread: Replaced my 4HDD box in my VR with a 6HDD
    VR, VX, VN Commodore's
    Dec 2008
    Default Replaced my 4HDD box in my VR with a 6HDD
    as the title states, the motor and trans is all in, ready for everything to be hooked up again, but the trans wires are hooked up, now ive done some reading and heard that the 6HDD box will not work if the previous box was a 4HDD? i hope this isnt true, i dont feel like taking the motor and trans out for the 3rd time,, all the wires are hooked up, linkage is hooked up, torque convertor is all hooked up, all seems fine, ive only started to worry because ive just done some reading up now....
    Dont Take Life Too Seriously, You Never Get Out Alive Anyways.
    2002 Series II VX SS - 6spd - 5.7L - Black - Red Leather <3
    Dec 2008
    i also should add, this motor (out of another VR) had a 6HDD trans on it in the original car..
    when i put the motor in this current car, it ran like a dream, just needed to come out to put a new rear main seal in, found out my 4HDD was stuffed, so i replaced it with the 6HDD.
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    Nah you shouldn't have any problems. Only diffecerents is 4hdd has 12 pins and 5,6hdd has 13 pins
    NEVER LATE IN A 355ci
    Dec 2008
    cheers mate
    VR WAGON
    Oct 2009
    I had my box replaced in a VR 5hdd... all good. But apparently the 6hdd is out of a vs. Computer reads different. If it works, I would love to know!
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Not sure but is the 13th wire somthin to do with the torque converter lockup? If so you may find it may not lockup. But if it all works when you drive it then i wouldnt worry about what you have read. Proof is in the pudding.
    Reaper
    Dec 2008
    had to put the 6HDD big blue chip in the computer.... and then it decided to change into 2nd...what gear does the torque convertor lock up? im guessing 4th?
    Dec 2008
    VR WAGZ was right, wont change into 3rd, then once its in second, wont go back in first unless your fully stopped and put it back in park then drive again, ***n sellin it, not rippin motor out for the third time
    VC SLE 5ltr
    Jan 2008
    in my commodore
    mate, the vs ecotec is more advanced within the wirring compered to the buick's if you were to change the box it would be recomended that you change to a vs auto pc before you try selling it, you may need to also change the engine wiring loom but you could normaly get them modified.
    if i were you i would have thrown a manual t5 in while the engine was out thats what i did to my ecotec, the t5 was not ment for an ecotec getrag. but hey if u have the patience, do it right the first time to avoid head f***'s works a treat.
    wish u luck man.
    cheers Ryan
    VR WAGON
    Oct 2009
    When you put the torque convertor in, did you spin it till it locked one way, then spin the opposite way, til it clicked, then a 3rd time????
    You have to do that to lock the convertor in.
    i thought it wouldn't work, still we can only try and hope!!!!!
    Dec 2008
    gsxr1201, i didnt do that, i just spun it until it went in.. might have to think about that...
    Dec 2008
    aussie91, this motor and trans was VR series 2, it was still Buick motors....
    VR Caprice
    Dec 2005
    If your convertor was not in properly you would have probably busted the pump and wouldn't get any gears.
    Mar 2008
    i need to replace the engine in my vr as well, its auto
    if i want to put an ecotec in it i will need all the below
    ecotec motor and auto box
    ecu, harness, bcm, keys ignition barrel ?
    does anyone know if the gearbox mounts are in the same place in a vr as per vs etc
    are the tailshafts from the vr going to be the same length
    thanks
  1. 7HDD v 6HDD
    By Mattrob in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2009, 09:21 PM
  2. transmissions, 6hdd vs 6hcd
    By alex2_s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2009, 12:12 PM
  3. 4HDD Auto
    By Chris E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2009, 01:01 PM
  4. 6HDD in a Series 2 VR Calais
    By Shane_Power1981 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-08-2008, 02:12 PM
  5. Replacing a 6hdd with a 7hdd.
    By Cappy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2007, 11:07 PM
