Results 1 to 13 of 13
Thread: VS Statesman Foglights
    HSV VS Senator LS1
    Feb 2009
    Adelaide,South
    Default VS Statesman Foglights
    Hey Guys
    i want to put foglights in my VS Statesman im pretty sure i got the wires going from the button to the fuse box under the bonnet... and the i got wires that go from the fuse box and they just stop at the headlight with a plug there,Can anyone tell me if there is another wire that plugs into the one at the headlight and goes down to the wires off the foglight..
    here is the plugs that stop at the headlight
    Thanks
    Attached Thumbnails Attached Thumbnails VS Statesman Foglights-image010.jpg   VS Statesman Foglights-image011.jpg
    Mar 2009
    not to sure about the statesman but i would think its the same as the commodores, the 2 plugs on drivers side near the head lights are for thermo fans, one is for the thermo fan on V6 models (not in-use on 5.0 but still in the loom) and the other goes to the smaller thermo fan that some have infront of the air con rad.
    HSV VS Senator LS1
    Feb 2009
    Adelaide,South
    vx s pack II
    Jan 2010
    aLKIDA
    To properly test the plugs and if they are in fact for the fog lights.
    Press the button to the on position and get a test light and test for power at the plug.
    The power on the test light should go on and off when pressing the fog light botton.
    This indicated that’s the loom for the fog lights.
    Test both sides.
    And if they are for he fog lights the plug on the diagram is a male connector and you can buy female connectors
    and crimp the female pins and slide it in the connector which mates to the male connector
    make sure the wires are thick enough for the current draw.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    His car didn't have factory fitted spotties, so he might not have the button in there.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Mar 2009
    its a bit hard to see where exactly those plugs are in your loom that you put pics on of, but there are defo 2 spare plugs on the 5.0 to the left of the rad as you stand in front that are for thermo fans.
    If you have a plug either side theres a good chance they will be for fog lights
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by westbad View Post
    The thing that put him off that, is the spotlight has a different plug. Or is there another loom that plugs into that loom, and then into the spotlight itself?
    cheers sexy
    vx s pack II
    Jan 2010
    aLKIDA
    VS l67 statesman
    Dec 2008
    HSV VS Senator LS1
    Feb 2009
    Adelaide,South
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    the pictured plugs are not foglight ones.
    follow the loom that goes over the headlight they should be wrapped up around there. they have a long appearance with two circular holes in the end.
    hard to explain but whenever ive seen them they have been black.
    hope this helps
    Verynice's Avatar
    Verynice is online now Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    hey nick, the plug should be taped to the indicator wire back at the front reinforcement bar, thats if it IS there.
    VS Statesman Foglights-img_1304.jpg click to enlarge
    HSV VS Senator LS1
    Feb 2009
    Adelaide,South
    alrite thanks Haydz ill look tomorrow.
  1. [VIC] VP SS Foglights
    By VQ-Assault in forum Parts And Other Items For Sale
    Last Post: 22-08-2009, 01:19 PM
  2. Are these the same foglights?
    By sprocket in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-06-2009, 01:14 AM
  3. FogLights
    By craigy09 in forum Electrical Wiring / Questions
    Last Post: 22-08-2008, 05:36 PM
  4. Foglights into SSX bar
    By Jesterarts in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-10-2007, 08:32 PM
  5. SS Foglights
    By ANDY_2430 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2006, 04:38 PM
