Results 1 to 8 of 8
Thread: Few Questions bout VR wagon
    VX SS
    Jan 2009
    Default Few Questions bout VR wagon
    Hey guys, just a few quick questions,
    First, my mate has a vr wagon, and we are thinkin of puttin the rear seats out of my vs acclaim in it.....coz mine has the seat that fold down in two, his only folds down as one, will the support for it be different? There is like a steel plate behind his seat at the moment, i assume for suport. But could it be done? (hope that makes a little sense)
    Also on the same car, he has lowered it on super lows and has his ajustable panhard rod in, its been aligned and setup right, but when he has a full lod it still rubs inside the left hand gaurd. We felt up in the gaurd and for some strange reason, instead of it being flat all the way round, they decided to add another ridge sorta thing in it and the tyre hits it and its nearly destroyed his tyre. Would it be better to get the panhard rod adjusted while loaded, or can you get that ridge thing rolled out, so its smooth? Once again i hope you understand me.....
    Any help would be greatly appreciated
    vs commodore
    Oct 2009
    Tamworth NSW
    It would most likely need adjusting while its loaded up.That way they can adjust the panhard rod to pull the diff across far enough so the tyre wont rub on the guard.You can flattern out the ridge under the guard.Best to get someone who has done it before if you dont want the guard ruined.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    The seat i cant be sure about, all i can say is it is the same body as the vr, they just slapped on a silver badge really. The engine is even the same, except for the v6 which was the ecotec, Sooo i would think the mount points will be there, but its only an assumption. And yes you can get the panhard adjust to suit but you can also roll the gaurd. I would go the panhard rod first since you got it.
    Reaper
    VR WAGON
    Oct 2009
    angle grinder and a flapper disc, touch up paint and a brush........take off the wheel grind away and dab, dab on the paint..... 15 mins done!
    VrWagz1's Avatar
    May 2008
    wollongong
    Quote Originally Posted by gsxr1201 View Post
    You could do this or you could folk out the $100 to have somone roll the gaurd properly
    Reaper
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    For the interior, the seats can be modded to fit, but they aren't a direct bolt in.
    Just get VS seats, as they have a different split for the wagons, or go one better and try and find Acclain or berlina seats, still have a 60/40 split, but also have headrests
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VX SS
    Jan 2009
    thanks guys, now, when you speak of rolling the gaurd, is that just the lip in the gaurd, or the indide of it? Coz the ridge i speak of is up inside the gaurd. Bout 3-4 inchs above the bottom of the gaurd.
    What problems will i have with the seats, im puttin vn calais seats into my vs acclaim so he is prob gettin mine, is it hard to fit?
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by VS32 View Post
    You can pick up factory wagon seats pretty cheap, so i wouldn't bother. Pretty sure theres a few how to's on modding the seats tho
    cheers sexy
  1. few questions bout vr 5ltr
    By vrcalais5ltr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2009, 10:55 AM
  2. quick questions bout vl axles
    By adrian222 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-04-2007, 01:58 PM
  3. Few questions bout current through barell wires
    By ascension24 in forum Electrical Wiring / Questions
    Last Post: 09-02-2007, 02:04 AM
  4. VN Wagon Questions
    By mazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2005, 03:09 AM
  5. VN Wagon Questions???
    By mazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-07-2005, 11:00 AM
