Results 1 to 5 of 5
Thread: VS11 auto trans flaring and sliping
    vs series 2
    Jan 2010
    Burleigh heads qld
    Angry VS11 auto trans flaring and sliping
    my series 2 vs v6 auto ,dosnt seem to want to reverse or drive forward when cold (bit like a sliping clutch on a manual) trans level is perfect, and oil is clean and not burnt. also takes a long time to shift into 2nd/3rd and 4th, is almost like there is not enough oil pressure, but once engine and trans are warm there is no problem, there is a fault code 24 which is speed sensor, and i have replaced it last week and deleted the code and i still have the same problem, am just wondering if any one has had the same issue as i am having or kno a fix,
    vs series 2
    Jan 2010
    Burleigh heads qld
    Mar 2009
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Have it checked at a trans shop, but to me sounds like its just about shagged. If so, thin if you plan on keeping the car it maybe worth rebuilding it, otherwise a cheap ebay one might get you out of trouble to get it moving.
    Reaper
    vs series 2
    Jan 2010
    Burleigh heads qld
    yea i'm a mechanic myself, it just all of a sudden happend, have been told that it is possible that the filter can fall out, but before i go tearing it to bits i just wanted to know if this problem has happend to anyone before and if they have been able to fix it, if not i'm taking 3 weeks off work to have a good look at it, cheers guys
  1. Guard flaring
    By holdenhero in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-07-2010, 01:45 PM
  2. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  3. sliping
    By vq_statss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 09:47 AM
  4. auto sliping
    By Insanesinner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2006, 10:38 PM
  5. VS Auto Flaring
    By Koontz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2005, 02:20 PM
