Results 1 to 16 of 16
Thread: VS Fuel Pump
    VS Commodore Executive
    Dec 2009
    Talking VS Fuel Pump
    Can anyone tell me how much I should be paying to have my fuel pump replaced in VS Sedan Executive. I have been quoted $595 and think as a female I am being well and truly ripped off. Any help appreciated.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Get a written quoted as we don`t know if they are just doing the pump because most of the time the breather pipes need to be replaced aswell and they should replace the fuel filter so more money.
    They have to drop the fuel tank down on the ground to fit the pump.
    I`m thinking $500 max.
    If you got your quote from Holden then you are paying about $130 an hour.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Dec 2009
    Getting it fixed at a local repairer, but starting to think Holden may be cheaper because I can buy the kit alone for under $100
    VS Acclaim V6
    Jan 2010
    wow!
    i paid half that about 5 years ago to get mine replaced. i know mech labour has gone up, but christ the hardest and longest part of the whoole ordeal is if the customer had a full tank of fuel.....
    VS_Pete_1's Avatar
    Dec 2007
    I`m just gressing the price but.
    vr
    Jun 2009
    wtf..$595. thats just a plain ripoff. the tank does not need to be removed at all. any competent mechanic will have the pump and filter replaced in an hour. the pump will cost you $100 give or take a few dollars. i suggest you go to another workshop.
    Quote Originally Posted by v6monstar View Post
    dude your piston slapping your going to have to titan up your pistons be for you throw a con rod throw the side of the of your engine
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    $595? RUn away Fast lol. The Pump Should be no more then $150. And a bit more for labour to install.
    GMH95's Avatar
    GMH95 is offline Sorry I dont do Resprays
    VS Berlina S1 3.8l
    Jan 2009
    Western Suburbs
    yeh dats a rip off i got a new pump, sender unit and fuel filter fitted for $320
    Mar 2009
    ive just replaced the fuel pump in my ute, that cost me $117 for a new pump and i fitted it myself.
    With the utes you have to remove the tank, sedans and wagons you dont.
    Shouldnt take more than an hour to be fitted.. that price is very expensive..
    vr
    Jun 2009
    if you are in the s/e suburbs of melbourne, ill fit a new pump and filter for you for $250
    Mar 2009
    Quote Originally Posted by python_hunter1 View Post
    ill do it for $200
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Again, thats a rip. New pump $100, tank stays in and about an hours labour, 2 at abolute max. It took me less than 2 hrs and im so not a mechanic.
    $595 is just plain price gouging.
    Reaper
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    I had mine done recently and all up it cost me $240 (including the pump). Tell the mechanic to go and take a hike.
    VS_Pete_1's Avatar
    Dec 2007
    Thanks guys I thought the tank came out or dropped down you learn something everyday.
    My wagons tank was dropped down but all the breather lines were replaced aswell.
  15. #15
    VR WAGON
    Oct 2009
    JUST DONE MINE AGAIN!!! had the tank out cause I broke the internal hose replaced the tank with the existing pump in 1 hour flat. couple of weeks later the pump went ( 95 bucks repco bosch) replaced in 25 mins with 55 F'N ltrs of fuel in it! you dont have to touch the tank, just remove 6, 7 mm bolts, the fuel will start gushing out( have your buckets ready) !!!!!!!!!!!!!! put on the pump, bit of a fiddle to get it in, fil up ya tank and off you go!
    If you live in Bris I will do it for 100 bucks, you bring the pump.
    Jase.
  16. #16
    Dec 2009
    You just need to jack the car up and if it's a solid axle let the diff drop down and there is enough room to get the pump and sender out of the tank without removing the tank. It's a good idea to syphon the tank out as much as you can so you don't spill fuel everywhere because it will run along the bottom of the tank and disolve the bitument paint that is on the tank under the metal tape where the mounting brackets go over. It burns too so use rubber gloves.
    If there is any petrol smell when you fill the car consider removing the tank and replacing the breather lines and get a new bit of hose to connect to the filler neck while your at it, put vasoline on the inside of the new hoses as it makes them slide on really easy.
    Replace the fuel filter as well and buy some fuel line and replace all the external fuel hoses that connect to the tank as well.
  1. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  2. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  3. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
