Results 1 to 17 of 17
Thread: what should i salvage from my VS wreck?
    VS Ute
    Apr 2008
    Bentleigh East, VIC
    Default what should i salvage from my VS wreck?
    Hi folks,
    I have a VS acclaim I'm wrecking and I need to get it out of my driveway before wifey loses it. But before I send it to the scrap heap, I'm wondering what parts members think I should keep as spares for my VS ute?
    I don't have the room for salvaging the drivetrain but I would like to hang on to those bits'n'pieces that tend to fail/wear out/crack/break every so often.
    Thoughts?
    D.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    what's the interior like, i'm after some bits for my VR. does it have intact chrome strips?
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    tail lights! the acclaims have clear indicators. umm and probably the seats, console...all the fuses(good for spares)
    VS Ute
    Apr 2008
    Bentleigh East, VIC
    Quote Originally Posted by nathanwright View Post
    interior isn't the best and the chrome trim has seen better days.
    VS Ute
    Apr 2008
    Bentleigh East, VIC
    Quote Originally Posted by Disturbed_vegeta View Post
    Tail lights are a prob - this one got rear-ended. The rest of the body is pretty good though and i've salvaged the indicators. and good point about the fuses - can never find the right fuse when I need one!
    Dec 2009
    I'd look at keeping the following;
    Alternator
    Starter Motor
    Battery?
    Headlights
    Brake calipers and rotors
    Door handles
    Door Window mechanisms
    Central locking
    ECU and BCM
    Dash cluster
    Airbags
    Wheels?
    Aircon compressor
    Radiator
    All depends on how much space you have.
    VS Ute
    Apr 2008
    Bentleigh East, VIC
    thanks wortus - hadn't thought of the starter motor and compressor. the rotors are shot but i didn't think to salvage the calipers - do they tend to fail in holdens? on a related note, is it worth keeping the master cylinder?
    Dec 2009
    it's really only the caliper seals and pistons that will fail but I'd keep the calipers incase one ever gets too corroded or a stripped thread. You can keep the hose attached and seal up the end and they will keep better but would need reco before use if left a while.
    I'd also consider keeping the coil packs and DFI module, hand brake cables, heater core, heater tap, blower motor resistor.
    1999 vs ute series 3
    Oct 2009
    Hey im in neeed of a centre console ash tray if your willing to sell??? plz cant find em any were :/
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Could always try to sell parts to members if they need it dude.
    Like panels and such.
    What colour is the car?
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    VS Ute
    Apr 2008
    Bentleigh East, VIC
    Quote Originally Posted by antoniomazzurra View Post
    plastic lip on the corner is broken, but its yours if you want it. pm me and we can arrange something.
    Quote Originally Posted by Wombles View Post
    its a dark blue (not sure what the holden lingo is) - the rear end is cactus, but the rest of it is pretty straight. i'll post it up on the classifieds forum after i pillage it. (i need 20 posts to be able to place an ad on that forum - only halfway there )
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Then hurry up and post away. Haha.
    My Commy
    Discuss.
    VN S1 (was VR) V6 Hilux
    Apr 2009
    Apart from already stated above;
    Injectors
    Rocker covers
    Harmonic balancer
    Globes
    Plastic knobs and handles form inside
    Dash Combo meter if low KM on odo, plus gauges do fail
    Look for stuff on eBay that has a lot of bids or good bid prices to determine stuff to sell that is in high demand. You will probably be looking for that stuff yourself in the future and if you change car, it will sell easy.
    Master cylinder is 50/50 and you can do an storage cost/replacement cost analysis as to keeping it. If it works perfect, then it is worth keeping. I know of a VN unit that lasted 18 years before it failed. Seal kit was about $70, plus my time and skills to rebuild.
    '96 VS Commodore Equipe Sedan
    Apr 2009
    You should be able to get one from the wreckers... I got one the other day in good nick for $5.50 Inc GST...
  15. #15
    VS Ute
    Apr 2008
    Bentleigh East, VIC
    Quote Originally Posted by v6lux View Post
    Injectors
    Rocker covers
    Harmonic balancer
    Globes
    Hadn't considered rocker covers - do they have problems with age?
    From what I could tell on ebay, most of the parts that are in high demand are either "buy it now" new or come off limited edition/top-of-the-range models. But I did notice some demand for parts already mentioned in this thread - so thanks guys!!
    I'm thinking to salvage the heater core - is it worth the pain?
  16. #16
    Apr 2009
    Quote Originally Posted by deez View Post
    With the rockers, they are made of some sort of composite material and seem to leak when they are tapped, like a screw driver point dropping onto them. Also if the engine ever has to come out, they get damaged easily. It's one of things I have had trouble with - twice in 14 years.
    As for the heater core, if your keeping the same type of car long term and got the space, it could be a real saving!
    A lot of these things will be cheaper in the future from wreckers, then again they become rarer. In the end you got to make a call on what you can easily store and the chance of it costing you money to get rid of if you move house.
  17. #17
    VS Ute
    Apr 2008
    Bentleigh East, VIC
    I do intend to hang on to my ute for at least 3 years so I think I will hang on to that heater core. At the very least, it may be fun to rip into the comm's interior. Thanks for the advice lux.
  1. VP BT1? Wreck or Rego??
    By Zeussy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2010, 02:18 PM
  2. WTB: 5ltr Wreck
    By Pav in forum Swap / Wanted to Buy / Trade
    Last Post: 05-03-2008, 06:54 PM
  3. any1 got a vn wreck
    By vn_lexcen_s2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2007, 09:21 PM
  4. WTB vl calais wreck,
    By binkztarr in forum Swap / Wanted to Buy / Trade
    Last Post: 04-03-2007, 11:59 AM
  5. Wreck value for VR
    By manvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2005, 04:29 PM
