Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Scooter79
Thread: what grade oil should i use?
    VS Commodore
    Jan 2010
    Default what grade oil should i use?
    What grade oil should i use in a VS commodore with 211xxx kms?
    HSV.006's Avatar
    HSV.006 is offline Apprentice Mechanic
    vq statesman. CSV strada 5000i.
    Sep 2008
    adelaide
    VS Commodore
    Jan 2010
    thanks for that, does it make any real difference between 20w 50 and 15w 40?
    vs commodore
    Oct 2009
    Tamworth NSW
    It doesnt stay as thick as the 20w50 stuff when it gets hot.Using 15w40 is only recommended for use when the vehicle is used in cold climates where it snows etc.
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    As I've said in previous threads asking the exact same question, oil has come a long way since the ecotec was released in 1995. Back then 20w50 with an API rating of SG was the best thing avaiable. But if you have a look at the recommended oil in a VX or VY ecotec handbook it will say 10w30 (API SL or SM).
    Me personally I use a synthetic 10w40. Nulon to be specific.
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    I will go against you saying that 20w50 is more suitable, reason being the car has done a fair few kms. IMO that oil is to light and will burn to quick.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Quote Originally Posted by PMS-247 View Post
    I have to agree. For a while I used 15W40 and I was burning it at a considerable rate. As soon as I switched to 20W50 or 20W60 my oil consumption stopped.
    Mar 2005
    South Coast, NSW
    Mine has just racked up 200,000kms and have had no problems with 10w40.
    calais24/7's Avatar
    Jul 2009
    Each to their own i guess, i put 10w40 in the vl stupidly and it has done 225 thousand, it ran like a dog and actually caused me car to backfire under deacceleration Put 20w50 in and it runs alot smoother and no farting
    VS Executive Wagon
    Jan 2010
    I've just filled my brothers 1996 VS Commodore with Shell HX7 15w50 Synthetic (suited to older engines). The car has 306,000km on the clock. So far so good...
    vz sedan vs ute
    Jul 2008
    newcastle nsw
    do the oil chang at 6month or 10,000kms what ever come first.... u have no problem what oil u use.... i get my both cars done at kmart auto care and in the vs ute they use shell helix 10 30 semi sythetic...oils have change since i bought the old girl 14 years ago (mean me ute)
    http://shellus.rapidhost.co.uk/landing.asp?cid=2&selCountry=Australia&selLanguage =1 - AUSTRALIA
    Mar 2005
    South Coast, NSW
    Hey stick, how much are they charging you for an oil change? Helix is only $38 for 5L and a decent filter $8. If you've got a 19mm socket or spanner you can do the VS yourself.
    The VZ is even easier with the oil filter at the top of the motor.
  1. Replies: 10
    Last Post: 27-04-2010, 10:00 PM
  2. What grade fuel for ecotec?
    By nevj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 10:26 AM
  3. Oil Grade
    By kenwstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-11-2006, 05:39 PM
Tags for this Thread
