Results 1 to 4 of 4
Thread: Changing a Vr auto trans to a vn auto trans
    V6 VR Berlina
    Jan 2010
    Default Changing a Vr auto trans to a vn auto trans
    hi i've got a vr berlina v6 and i just bought a BT1 engine that came with a vn auto trans, I'm trying to get some ideas on how i might be able to hook up the vn trans, because its a bit different to the vr trans
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the only real issues is you need to fit the VR speed sensor gear on the output shaft of the trans in the rear housing and the sender itself on the outside so the ecu see speed and get the error codes turned off and fit a kick down cable pin on the throttlebody for the cable to attach chrrr on here had a T700 in his vr for months till we killed it
    V6 VR Berlina
    Jan 2010
    в∞ѕтεכ √&
    Jul 2008
    NZ
    forgot you will loose torque convertor lockup as well
  1. auto trans
    By ironsavage in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2009, 07:08 PM
  2. VS V6 auto trans, in SA
    By churnit in forum Parts And Other Items For Sale
    Last Post: 16-03-2008, 12:08 PM
  3. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  4. VR Auto Trans
    By sicko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2006, 11:18 PM
  5. auto trans fluid changing
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-03-2006, 05:16 PM
