Hey, after pulling out my cluster and re-fitting it to just change the speedo pin my indicators won't work from the side switch on the sterring wheel, the hazards work fine, the high beam works fine, it's just the left and right indicator switch? Any ideas?
EDIT: After a search, bashed the shit out of my hazard switch must of been jammed, they now work.
Make sure all the plugs are put back in its place. behind the cluster.
And also check the tracks on the back to see if any are burned out or Brocken.
If this is all fine check if the stalk switch is giving signal out with a test light.
Haha - if it does stuff up again Kurt when you put the cluster back in you might have broke a part of the green track on the back (i doubt it tho).
