Results 1 to 20 of 20
Thread: Thermo Fan switch bypass
    VS ute
    Mar 2007
    Default Thermo Fan switch bypass
    Can somebody please tell me which wires do you earth out to make the thermo fan come on ,I found the post on vn & vp v6 but I have vs v6 auto and the computer is different
    Thanks in advance for any help
    Cheers Garry
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Do you want to do hi or lo speed? - hi is a bit noisy and low is usually OK to keep temps down with hi for the aircon.
    VS ute
    Mar 2007
    hako i would like high speed as the ute gets hot in traffic when I am towing my boat ,also if is on highI will here it and turn it off when I dont need it , thanks for your help mate
    Cheers Garry
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    OK - I'll play with it this arvo...from the wiring diagram there is a blue/white tracer wire that goes to the hi speed relay and then to the ECU....so if I short that to earth the fan should come (ign on). I'll try it and take a pix.
    vx s pack II
    Jan 2010
    aLKIDA
    hey mate on the vs commodore your power train control module supplys a earth signal to the fan relay
    the colour of this wire is blue/white.
    It comes from the PCM.
    The location of this wire is F6 on the PCM plug. Or you can go to the harnness near the relay.
    Suppy earth. with the ignition on it should work.
    Check with a test light or a multimeter to confirm the earth supply of this wire.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Well that was a lot easier than I figured....pix will tell the story.
    pix 1 is location of blu/whi wire at back of relay (just for info)
    pix 2 is where that wire also runs...to an easier location near the top rad hose
    pix 3 is the cover removed and wiring exposed - it's the blu/whi one we want to earth
    pix 4 is of the blu/whi wire with a pin thru it and wire running to earth (batt negative)...when this wire is connected with engine running the hi speed fan comes on....no bad effects any where else down the line so it appears safe!!!
    So. you need to simply run a wire from this blu/whi cable into the cabin to a switch and earth the other side of the switch. Ign must be on for the fan to work.
    I'll wire it up properly and do some more pix and then a "how - to"
    Hope this helps.
    Attached Thumbnails Attached Thumbnails Thermo Fan switch bypass-fan1.jpg   Thermo Fan switch bypass-fan11.jpg   Thermo Fan switch bypass-fan111.jpg   Thermo Fan switch bypass-fan1111.jpg
    vx s pack II
    Jan 2010
    aLKIDA
    You could actually find this wire at the PCM.
    And is located on the f6 pin.
    You don't have to run it through the engine bay mate.
    If any one is curious this wire color is the same on the VTs. blue/white
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by PRAVX II S View Post
    I considered doing this but figured that I'd have to remove the kick panel to access the ECU and then run a wire across the dash over the heater unit.....so breaking into a wire with easy access and then running a wire thru the bulkhead seemed the simpler option to me. I also prefer not going near the ECU as I figure I'll break it although I must admit it would look a bit tidier.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    LOL, this brings back memories.
    i'd do it at the PCM, saves running a wire though the firewall.
    i though i'd linked wiring diagrams in my How-to for the VS models
    the real problem is that they run the VS so bloody HOT to begin with. i'd run a cooler thermostat and reset the on/off temps in the tune to suit. like i did with mine. for towing i'd consider fitting a better radiator. maybe a V8 one and a great big external trans cooler
    Body by Holden, Soul by Brock
    the Legend will live forever
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the engine and cooling system is in good order, the car should never overheat under normal operations. Fitting a cooler thermostat and larger radiator may keep the engine cooler but you sacrifice part of the research design advantages of the Ecotec system ('Emissions Control Optimisation TEChnology).
    Most if not all modern engines run at high temperatures to produce more power with less emissions.
    But, I'd have to admit that I prefer a cooler running engine.
    immortality - do you have the link for the "how-to" you did on wiring the fan ----- that will save me doing one if you've done one already.
    vx s pack II
    Jan 2010
    aLKIDA
    vx s pack II
    Jan 2010
    aLKIDA
    I would put I diode in line on the blue/white wire to protect the PCM of any back feed or short to the PCM
    Inside the PCM A transistor supplies the earth to the relay. And if this transistor stops working you could have problems.
    It might not happen but I rather be safe then sorry.
    up to you bro.
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    Seems pretty easy, if I ever have to do this ill make sure to read this agian. Cheers.
    Check It Out
    My 93' VR Executive
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    up to you bro.
    That is a good idea!
  15. #15
    VS ute
    Mar 2007
    Default Fan by pass still not working
    hako thanks for the trouble you have gone to ,but I still cannot get the fan to come on ,first up there is no blue/white wire to the fan motor ,there are 4 wires going to it ,[see pict] when I put the test light they show as all negitive ,so I dont know whats going on,the fan works fine comes on with a/c and temp switch
    Cheers Garry
    Attached Thumbnails Attached Thumbnails Thermo Fan switch bypass-p1310030.jpg   Thermo Fan switch bypass-p2010033.jpg
  16. #16
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The blu/whi wire that I show next to the radiator top hose actually goes to the A/C hi/lo pressure switch but it also is the same wire as shown at the back of the relays and also the one that praxIIs talks about at the ECU.
    I think the problem lies in the fact you have a ute....and if it's series 1,2 or 3.
    It's also possible you have opened the wrong taped cable....look in the same are near the top hose for another taped cable...open it and see if the whi/blu wire is there. The taped cables you need to locate go to the hi/lo A/C pressure switch which is part of the A/C drier.
    I prefer not to play with wires near the ECU.
  17. #17
    vx s pack II
    Jan 2010
    aLKIDA
    [QUOTE=BUSTER1;1443640]hako thanks for the trouble you have gone to ,but I still cannot get the fan to come on ,first up there is no blue/white wire to the fan motor ,there are 4 wires going to it ,[see pict] when I put the test light they show as all negitive ,so I dont know whats going on,the fan works fine comes on with a/c and temp switch
    Cheers Garry[/QUOTE
    The blue/white wire will run from the PCM F6 pin to the high speed relay.
    This signal is a earth.
    So find the right relay (High Speed) and under the relay holder you will find a Blue/White
    wire.
    This wire is only to turn the relay on and of. (It Controls The Relay)
    It does not go straight to the fan motor.
  18. #18
    VX SS M6
    Jun 2005
    i though high speed mode is when low is already running and it switches on the other motor behind the fan which makes high speed? dunno could be wrong
  19. #19
    vs commodore
    Oct 2009
    Tamworth NSW
    On my VS V6 theres only 1 motor on the cooling fan,its a 2 speed motor.It goes to high speed by connecting both the hi and low speed wires both to 12 volts at the same time,and both earths connected to earth at the same time.Theres 4 wires going to the fan motor,2 earth wires which Im pretty sure are black.And theres 2 live wires,one for low speed and the other for high speed.(but not on its own).The low speed wire is Blue/yellow,and the other high speed wire is orange/blue.But what you need to do to be able to manually switch the high fan on and off is go to the relays under the bonnet,and find the "eng fan" relay.Theres a blue/white wire that goes to this relay's socket,thats the wire that has to be earthed out to get the high fan to come on.All that needs to be done is to tap into that blue/white wire,join another wire to it and run the new wire to a switch on the dash or wherever,then run another wire from the other side of the switch to a good earth.
  20. #20
    VN V6 And XA 351
    Aug 2005
    Warwick QLD
    Sorry to bring up an old thread but I just went to do this to our vs. turns out the wire blue / white is live.
    Tested it near ac pressure switch an relay and it has 12 volts
    Any ideas?
    Jay
  1. How to fit thermo fan bypass switch
    By immortality in forum Holden Commodore How-To's
    Last Post: 18-04-2012, 06:06 PM
  2. How to bypass the hazard light switch (temp rewiring)?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2011, 05:17 PM
  3. thermo fan bypass switch?
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-07-2009, 12:56 PM
  4. Netruel Bypass Switch
    By jwk87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2007, 11:19 PM
  5. thermo fan switch
    By cracker in forum Electrical Wiring / Questions
    Last Post: 19-08-2005, 10:32 PM
