Results 1 to 11 of 11
Thread: Urgent! VR column shift auto. start inhibitor switch?
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Default Urgent! VR column shift auto. start inhibitor switch?
    Hi. My g.f's brother has a VR v6 wagon with column shift auto.
    It suddenly developed a problem where sometimes it wouldn't start in P or N. The car primes, but will not kick over The RAA guy said that it was the inhibitor switch or something? He bridged a connection in the starter relay and it worked, but he said that switch would need to be replaced asap.
    Can someone direct me as to where this switch is located, so that i can rip it out and replace it.
    If anyone has any diagrams that would also help
    Much appreciated.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Its under the shifter, pull off the center cover, there is a box that sits next to the shifter, its got a shaft that sticks out that goes to a lever on the inhibitor switch.
    think its 2 screws n it comes out, i got a spare but ur ages away.
    doubt wrekers would want more than 20 for it
    ________________________________________
    vb sle
    Jan 2009
    adelaide
    my missus vs dose this as well is the vs the same and are the switches the same in the floor shift as colum?
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    There is a how-to on fixing this, look up fixing "reverse lights" as it runs off the same switch and will or should fix your problem. They are little tabs that will bend in time and loose contact, well hopefully that is the issue. It could also be your immobiliser, check the error codes, if code 31 comes up you know it is the immobiliser.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Column shift inhibiter switch is completely different to the T bar version and lives under the car and not in the console. Instructions to adjust etc are long - pm me your email and I'll scan them for you.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    GTP 85's Avatar
    Aug 2006
    FYI.... finally got round to fixing this. After laying under the car and racking my brain over the location of the inhibitor switch, i finally located it. It isn't under the car as you suggested Hako.
    It's under the plastic shroud of the column shifter! I looked at my gregory's (asuming VS-VR were the same) and they aren't! Just to refresh, the car im fixing is a VR. On VS it is under the car on the side of the trans.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Well, that does make a difference! - I just looked at your ride and saw VS. Did you eventually fix it?
    vs commodore
    Oct 2009
    Tamworth NSW
    My VS(floor shift) has the inhibitor switch under the centre console,next to the gear selector.
    VS Berlina S2
    Feb 2010
    Just adding my 2 cents here. Early VS column shift autos had the inhibitor switch in the steering column, late ones had it on the side of the transmission. There is no defining break point of when this was changed.
    VRV6 ute
    Nov 2009
    ive got series 2 vr ute with colum shift and the inhibitor is on the box.
  1. how to change inhibitor switch?
    By fkford in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-11-2009, 06:52 PM
  2. what is an inhibitor switch and does a VN have one?
    By VN_chris in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2009, 12:31 PM
  3. Removing dash off a VR Ute Column shift auto.
    By VTSSDUDE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2006, 02:40 PM
  4. Manual console in a column shift auto
    By Matt H in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2005, 09:29 AM
  5. inhibitor switch
    By martynmac in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-09-2004, 07:53 PM
