Results 1 to 7 of 7
Thread: VS door lock problems...
    VS SS V8
    Oct 2009
    Townsville, Qld
    Default VS door lock problems...
    Hi all,
    I think it may be from all the rain up here in the far north in the past couple of days, but there's a problem with my door locks on my car... mainly drivers side.
    Central locking all works, but won't pull the drivers side front or rear door locks down... also opening any of the door handles from the outside is very difficult (hard to pull the handles up)... and I need to basically slam the drivers door to get the latch to catch when it's closed.
    Would a bit of crc or rp7 fix this up or should I go buy some spray on lithium grease?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As a quick fix I would saturate the latches with WD40 or similar - spray from above thru the window opening and thru any other orifices available. Otherwise you will need to pull the trims off which ain't nice in the Townsville heat/humidity where I spent 20 great years.
    VS SS V8
    Oct 2009
    Townsville, Qld
    Hi Hako,
    Yeah I did that when I got home this afternoon... and then TAC2'd the latches aswell coz everything looked really dry, any of the grease that was there definately isn't now. The drivers side door lock is still not locking via remote, but will unlock... if I lock it manually or deadlock it it's really stiff to turn. The door handles are also really tight on a the back passenger doors. I'll have to pull the trims off all the doors and see what's going on and give everything a good dose of TAC2... just can't do it now coz I have no garage and it's a bit wet up here thanks to good old Olga!
    1999 vs ute series 3
    Oct 2009
    maybe look at the red parts on the locks, mine were sticking out just a little bit so the lock wouldnt go down.
    VS SS V8
    Oct 2009
    Townsville, Qld
    checked the lock nibs already and it's not them causing the problem... I wish it was that easy! lol
    VS SS V8
    Oct 2009
    Townsville, Qld
    Checked the locks this morning and the drivers door still wouldn't lock...
    Drove to work... got out... pressed the button and it's all working normally again... looks like the lube must have loosened up what ever was sticky
    VS SS V8
    Oct 2009
    Townsville, Qld
    I spoke too soon... now passenger doors are locking, but the drivers side isn't. I think I'm going to have to pull the trims off and have a look at what's going on tomorrow.
    One thing I noticed was there was a bit of vibration in the outside door handle when I had the stereo cranked up... so maybe that's got to do with the issue of the locks not doing what they're supposed to.
  1. ignition/steering lock problems passenger door lock
    By timbuk3 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-02-2010, 08:21 PM
  2. VN Door lock problems/central locking
    By VN-Corey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2009, 07:42 PM
  3. Door Lock
    By commo82 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-09-2009, 08:20 AM
  4. Vp Door Lock Out
    By dean.ried in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2009, 11:06 AM
  5. one door lock won't go down!
    By Aaronvrcalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 11:12 PM
