Results 1 to 13 of 13
Thread: Fuel economy questions
    VR Series 1 sedan
    Jan 2010
    Default Fuel economy questions
    Hey all
    just doing the usual things to the commodore, as usual its had
    new leads,
    new plugs
    all oils changed
    trans serviced
    02 sensor changed blah blah blah
    my 2 questions are...
    1)what are most getting out of a tank with normal driving and maybe a punch from the lights maybe once a week/month? as i had 3/4 of a tank and she was gone in 200kms, and thats 2 trips up the highway included
    and 2) what do most peoples autos sit at on 100kms? as mine sits on 2k at 100 but it only seems weird to me as my mates vn use to sit on 1100 on the highway at 100 and seemed to use way way less fuel all together
    before i did the auto service (the oil was really brown and fubard!) i was following the girlfrend home and she was driving the VR and i noticed that it blew some burn fuel (black smoke) when it it seemed the car would be changing gears :S
    my VR wagons gauge didnt work (fuel or odometer) so i dont know what kms it was doing but she would take $60 and i could drive 20 mins to work every day and back and around town for 5-6 days before needing fuel so yeahh
    cheers all in advance
    My Rides.....
    1994 Holden Commodore VR sedan - my 2nd VR Click here for Members Ride!
    1988 Toyota Supra Ga70 - The Daily skid machine
    vs commodore
    Oct 2009
    Tamworth NSW
    Have you replaced the air and fuel filters.They make a big difference to economy when they get blocked up.
    VR Series 1 sedan
    Jan 2010
    yeah ive done the air filter and it was dirty and heck, almost say it was the orignal one!
    but fuel filter no.... i wanna do them as soon as i start work again (a week or so)
    the fuel use got fair better once i serviced the transmission so yeah, ill have to get new fuel filters really soon,
    cheers champ
    My Rides.....
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    i get average on the high way 8.9 and i have seen as low as 6.9 (l3 cluster) round town with long 50km/h streets and stop start, i get an average of 12.5 or so
    dont over look charge rate of the battery also, when all else is done the battery and alternator must also be good to get good ecconmey, also whan all plugs, leads, filters and oil is all done, disconnect the battery for a min or too to reset the computer. this resets the defoult values in the computer and will reset the counters, if you get what i mean.
    my tip on my exhust was as black as the ace of spaids and i tryed everything to stop the fuel coumption, in the end i had a foulty reg.
    also it ued to smell like rotten egg gas out the rear ( i did blame the fuel at one stage but since found it is not the fuel) replaced the reg that was charging just on 12.2v at idle no loads 11.5 with loads to a new unit and now chages at 14.5v. with no smell and realy good econmey
    VR Series 1 sedan
    Jan 2010
    good info dude, ive been meaning to reset the ecu for a bit now but i keep getting caught up, ill do it this weekend when i fix a leak ive found
    and ive checked my alternator already, a good strong 14.2 constantly, ive had alot of car issues with alternators but i studyed them and always sus them out when i get a new car now
    ill ust have to replace most things one by one as i know for a fact that the old owner just didnt give and crap and drove the car no matter what problems it had
    cheers
    My Rides.....
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    We get 700kms to tank in the mrs VR, And at 100kms its about 1800rpm. And yes change the fuel filter, we gained quite a bit. Also found using GM plugs gave us 100kms extra to a tank, appose to Bosch plugs
    VR Series 1 sedan
    Jan 2010
    thats weird but i guess their made EXACTLY for that motor so it makes sense also
    i have found a water leak that runs directly pass the sensor under the alternator that everyone rants causes issues so that was litterly just fixed then so im hoping that helps, also i reset the ecu so it can learn its fuel patteren again and hopefully get some more mileage
    cheers for the info dude!
    My Rides.....
    99 wh caprice
    Jan 2010
    nsw and vic
    i get about 400 on a 1/4 of a tank on the freeways and 200 on stop start not sure on how far i can get on a full tank as i never let it get under 3/4 but even at 3/4 my range till empty is about 480 to 600
    all show no go
    dan202's Avatar
    dan202 is offline ITZ A PIG
    I HOT VR
    Jul 2009
    lancefield
    i get 7.9-8.5 to the 100 clicks no matter how its driven but really good now hit a roo and got no fuel bill at all
    VS L67 Ute III
    Dec 2008
    Adelaide, Hallett Cove
    iv been getting 300 to a tank
    but lately been getting 400 and thats driving in 5th in a 60zone lol so revs sit at like 1k but i think i need new o2 sensors
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Leathal, a ute tank is 64 litres compared to a sedan that can have up to 80, or a wagon that has 68. People who get 700 a tank definately have larger tanks than your ute.
    Also, standard diffs and auto's go 1000rpm for every 55kph in top gear. So at 100 you should be sitting on approx 1900, but exactly 2000 on 110, depending on the condition of the auto box and your diff gears.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS executive
    Jun 2009
    this makes me sad seeing all these buicks getting better economy than my ecotec , atleast mine goes fast :P
    VR Series 1 sedan
    Jan 2010
    apart from my mates supercharged one, ive never felt a fast ecotech, i just cant stand them
    just a qurious question, if the harmonic ballancer is out would this cause fuel issues also?
    im only asking as when i got the car she had a severe engine shake when on idle or comming to a stop (so basicly idle), the gearbox mount has seen better days but its not broken, and when off i cant move the motor by hand like i could when i tore the mounts on the 1j,
    that and the ballancer has "VS COMMODORE" written on it in white pen so it HAS been replaced and might be just off ballance altho the shaking has gotten alot better since yesterday when i reset the computer, but the ****in shitty E10 thats in there is causing it to miss so ill have to clean that out, i hate it when thats all you can get, the assholes!
    cheers
    My Rides.....
  1. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  2. Fuel economy, oxy censor questions, VS 5 litre
    By Cobez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2009, 08:45 PM
  3. Bad fuel economy, strong fuel smell?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 08:43 PM
  4. Memcal and Tuning Questions for fuel economy and response
    By DzRBenson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2008, 04:13 PM
  5. fuel economy questions vs ecotec
    By burnsy150 in forum General
    Last Post: 28-12-2007, 10:24 AM
