Results 1 to 8 of 8
Thread: VR SS Manual Cruise Control Problem!!!
    VR SS S2
    Dec 2008
    Newmerella
    Default VR SS Manual Cruise Control Problem!!!
    Have i installed all correct parts for the crusie control to work. For some reason it wont turn on... but i do get a click from the bcm when i hit on... also nothing is coming up on the cluster like CRS or ON.
    I have installed.
    *New BCM and from a VR Clubsport
    *Module and bracket in engine bay
    *Brake and clutch switch
    *Stalk for cruise
    All the plug were there i just connected them.
    Is there a relay under dash or under bonnet that i might be missing...
    Cheers..
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    I think the computer plays a part in this and having a manual ecm it wont let you enable cruise control.
    Chirpstr's Avatar
    Sep 2007
    You could try splicing and running a white wire from the cruise module (under hood) straight to the violet/white coming from the speed sensor (on the gear box)....again spliced as well.
    Good Luck.
    Edit: actually according the wiring diagram you already have one running to the speed sensor from the module (green wire) connect that to white.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You also need a relay for the fuse/relay panel under the steering wheel. Note- this is on VS....I presume VR would be identical.
    ethann's Avatar
    ethann is offline Low And Luxurious!
    '11 WRX, '73 Stingray, Lifted/Locked GQ.
    Dec 2009
    Newcastle, NSW.
    Does this mean once I put my manual conversion in my stato the cruise won't work?
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Default BCM Change Not Needed!
    Hi,
    The cruise control is independent of the BCM, so you did not have to change the BCM.
    Cheers.
    VR SS manual
    Apr 2006
    have u had the cruise actiuvated with a scan tool for your BCM? and have u installed the bulbs in the dash cluster ?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    first problem maybe that the crs light bulb is blown. 2nd, make sure things like the switches are ok and adjusted right and your brake light bulbs arnt blown. And i think there is a relay under the dash somwhere i beleive that may need installing.
    Reaper
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. cruise control in a manual vr
    By tangooly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2008, 10:42 PM
  3. cruise control in manual vn
    By Clunt in forum Electrical Wiring / Questions
    Last Post: 04-01-2008, 09:39 AM
  4. cruise control on manual. help plz
    By vrbenno in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2006, 06:13 PM
  5. Cruise Control in manual
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-07-2005, 11:51 PM
