Hey guys,
Did an error check and it came up with a code 19 Wich is Throttle Position Sensor Stuck.
How do i go about fixing this? Take it of and give it a good spray with a water dispersant?
Thanks guys.
i just got another tps and replace it with the old one. im not too sure about if theres a way to clean them out and make them work properly again
If the car is running OK it may just be a random error....wipe the code and retest in a day or so.
you might be better off changing it.. i was getting TPS fault codes.. took it off.. cleaned it.. put it back on and made it worse.. because thier positioning has to be perfect.. it was throwing codes because the voltage going to it was too low (too old??)
Had an EFI specialist sought it out.. ended not costing me much... no more than 200$
but that was for a rodeo commodore should be noticably cheaper.
A good sign it's playing is up is a noticable drop in RPM on 1st intial press off GO pedal e.g. sitting at lights.
About as handy as tits on a bull
How Much does a TPS cost cause the local Holden dealer said $149 and that sounds like a bit much would i be better off getting one off Egay? cause I've found a few that are a lot cheaper
If you get a cheap one like from ebay make sure you get a decent warranty with it.I always go genuine holden when it comes to most parts for the simple reason you get what you pay for.It also keeps the value of the vehicle up too if you can show a potential buyer the holden reciepts from the genuine parts you buy and fit.
just get a cheap TB off ebay and grab it off that. If not, get a tps from the wreckers. couldn't be that much. I think i have one here for an ecotec if your stuck
Check out My SV8 One Tonner
You can get a lot farther with a kind word and a gun than a kind word alone
I payed $80 brand new from holden for a 5 litre.
