Results 1 to 5 of 5
Thread: [VR V6] changing leads, plugs and radiator
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Cool [VR V6] changing leads, plugs and radiator
    hey so, planning to change the radiator, leads and plugs and thermostat on my VR tomorrow. never done it before but it looks easy enough, anything I should know? tips, things not to do?
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    remove plugs and leads one by one and swap over and as for removing the rediator, remove the bottom hose first and allow to empty then undo the top hose and take out and hose out
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    yeah ill give the engine a bit of a flush too (cooling part), cos they old radiators a bit rusty.
    how do I get plugs out?
    Dec 2009
    It's a good idea to draw yourself a picture of which spark plug goes to which coil terminal and keep it for future reference. Be careful pulling the leads off as they can break easy, pull them by the thick part right near the spark plugs. You need to use a socket set with the proper spark plug socket and don't over tighten. I used a torque wrench to do my plugs up on my ecotech.
    Given the coolant is a bit rusty you might want to use a radiator flush fluid before you drop the coolant. Engine block drain plugs from memory are not so easy to get out you can disconnect the heater hoses and flush it all out with a hose and refill the system with clean water and let it circulate for a while and when cool empty again and reflush. If it's still dirty do it again.
    When you add the new coolant firstly make sure you have got at least 5 litres of water out of the system and add the concentrate then top it up. Remember to bleed the system properly. I use the Nulon Long Life Coolant as it is a quality product, says it lasts longer and you don't need to use the pellets unless a minor leak shows up afterwards. Coolant shoudl be around 50% to a max of 60%.
    VN S1 (was VR) V6 Hilux
    Apr 2009
    Quote Originally Posted by wortus View Post
    Like in this picture;
    Attached Thumbnails Attached Thumbnails [VR V6] changing leads, plugs and radiator-p1010283-small-.jpg
  1. PLugs and leads
    By Joshren in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-08-2009, 08:07 PM
  2. Changing leads and spark plugs
    By gogoboygareth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-11-2008, 06:19 PM
  3. changing plugs n leads
    By chris239 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2008, 12:17 AM
  4. PLUGS and LEADS
    By statesman_wagon89 in forum V6 Development And Modification
    Last Post: 30-03-2006, 03:03 PM
  5. Plugs/Leads
    By Spyper in forum General
    Last Post: 27-12-2005, 11:19 PM
