Results 1 to 13 of 13
Thread: radiator help
    sprayzz's Avatar
    sprayzz is offline sprayzz
    vs commodore
    Dec 2007
    Default radiator help
    hey guys i have a leak on the left side of radiator just below the pipe.obviously i need a radiator lol but this has happened once before recently vertually same place was wondering what it could be from.(pressure) orrr........i dont wana get another radiator if its just gana do it again? has anyone had the same problem anything would be great!..
    cheers
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by sprayzz View Post
    cheers
    Which side do you mean? Driver or passenger? And is it coolant or trans fluid?
    I just replaced my (original) radiator, and it turned out that about an inch of the top intake pipe had clean snapped off. I thought it was some kind of hairline crack somewhere at first, but it just turned out that the hose didn't have enough pipe to clamp on to.
    sprayzz's Avatar
    vs commodore
    Dec 2007
    driver...yeah was coolant yeah i have checked all my hose they are fine.. im just thinking maybe there is to much pressure when its hot...maybe radiator cap? just stumped atm
    vs commodore
    Oct 2009
    Tamworth NSW
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If it is leaking from where you describe, pretty soon it will fail completely and dump all your coolant on the road....this will invariably happen when you are driving through "the bad part of town" and, guess what, your mobile battery is flat. Driving as little as 500 metres with no coolant will cook your engine.
    New radiators are as cheap as $100 or less from the wreckers.
    I wouldn't think the cap is increasing the pressure as with age they lose pressure if anything plus the usual fail point is a hose.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    mine has just cracked on the drivers side right near the fan mount, verry common problem.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by moff_man View Post
    How many K's?....I've got 230k's and starting to worry.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Quote Originally Posted by hako View Post
    I got mine repaired at about 180k just below the top radiator hose on the side.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Common problem for it to crack there. When I went to buy a new radiator the guy described the entire crack to me and where it would be before he lifted the bonnet lol.
    Not sure if the Alloy tanks would stop this from happening or not.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    mine did the same thing, replaced the original one with a sweet aluminum one and replaced my rusted thermostat as well. runs so much cooler now =D
    VS_Pete_1's Avatar
    Dec 2007
    Where do you get the aluminum one mate?
    moff_man's Avatar
    Nov 2008
    mine has 265,000km
    not shure if it is orignal tho.
    i have also seen them crack on the other tank and right in the crimp up against the core
    VS Berlina 3.8
    Dec 2008
    My original failed at 290,000.
LinkBacks (?)
  1. Radiator VN serie 2 (radiator cap) on a serie 1 (no raidator cap) ?
    By zai in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2009, 12:07 PM
  2. changing VN S1 radiator to VN S2 radiator
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2009, 06:30 PM
  3. Radiator fan
    By mezza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-11-2005, 04:09 PM
  4. FS Near new VB-VC-VH-VK V8 Radiator
    By Cane_It in forum Parts And Other Items For Sale
    Last Post: 19-11-2005, 06:20 PM
  5. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
