+ Reply to Thread
Results 1 to 21 of 21
Thread: VR V8 wont start when hot...??
    VX II Calais LS1
    Jan 2010
    Default VR V8 wont start when hot...??
    Hi guys ive got a VR 5.0 V8 and when it gets hot it wont start, the fuel pump wont prime if i sit there 15 mins and let it cool down it will prime and the car will start.. im lost as to what is causing this..
    So far ive replaced the following with brand new parts..
    Fuel pump
    temp sender
    oil pressure switch
    ignition module
    oxygen sensor
    fuel pump relay
    efi relay
    What would cause the fuel pump to not prime?? as soon as it primes it starts and drives fine
    any ideas???
    Thanks
    VX II Calais LS1
    Jan 2010
    88GreenVN's Avatar
    88GreenVN is offline Almost not here! 88GreenVN W427 88GreenVN W427 88GreenVN W427 88GreenVN W427
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    most common issue is the starter motor not wanting to turn the motor over when hot.
    Fuel pump should not be a problem if you have replaced it.
    and 3 Dangerous non ABS VN's
    VX II Calais LS1
    Jan 2010
    it turns over fine but wont start until the fuel pump primes which only happens when its cooled down for 15 mins, this one has got me stumped
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by bandit10 View Post
    may well be a fualty pump - or was it doing the same thing before replacing it?
    VX II Calais LS1
    Jan 2010
    was doing the exact same thing with the old pump so cant be the fuel pump.
    Is there some sensor that cuts off the fuel pump if it thinks somethings wrong..??!?!
    I would of thought it would log a fault code but nothing comes up just 12 12 12 repeated
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor Vee-ard Berlina
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Low oil pressure will cut the fuel pump off, as a safety precaution. oil light not on/disconnected? Oil flows easier when hot = less pressure. Also check wires around oil pressure switch.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by Vee-ard View Post
    ive replaced the oil pressure switch with a new one and its still doing the same, oil light is not on.
    It will run fine once the fuel pump primes but then if you turn it off it wont start again until its cooled down.
    Is there anyway to check the oil pressure is correct?? no dash warning light is coming on, globe not blown as it lights up when engine not running and key in acc position
    Mar 2009
    you can rule out the EFI relay, if the EFI relay fails the fuel pump takes power direct from the oil pressure switch which you say you have replaced as well. The car will crank over for longer until the oil pressure is up before it will start if this happens.
    The temp sensor is part of the fuel system wiring also, did you replace the sender or the sensor? theres 2 temp probes in the inlet manifold next to each other.
    hako is offline Donating Member hako Senator hako Senator hako Senator
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Must be the ECU. You could trick it by wiring a switch into the oilpump circuit to make it seem as though oil pressure is up.
    VrWagz1's Avatar
    VrWagz1 is offline The Wagon on Wheels.. VrWagz1 Monaro VrWagz1 Monaro
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    You need to find out if the fuel pump is getting power. If it isnt go back to the relay and see if it is coming in. If not you need to find out why. First test would be the ecu output for that relay. Then see if that is making all the way to the pin connector(edit: if the ecu sinks the voltage then it may appear to be on all the time with a test light, which happens somtimes but cant be sure).
    Reaper
    vr commodore
    Jan 2010
    hi guys i have a vr wich was doing the same thing i was told two chaNG THE CRANK ANGALL SENSORRS WICH NEAR THE LEFT HAND SIDE BEHIND HARMOMNIC BALINCER I REPLACE IT ON MINE NO MOORE PROBLAM
    Mar 2009
    Quote Originally Posted by bubba2pac View Post
    V8's dont have a crank angle sensor
    94 VR Calais V8
    Aug 2007
    Sydney, NSW
    Crank angle sensor on a V8.........I like that.
    Anyway down to business. I guess you have seen the circuit diagram of a VR V8?
    see this link:
    http://memcals.com/pdf/VRV8%20Wiring%20Diagram.pdf
    The signal to prime the fuel pump comes from the ECU [pin A1] and goes to one side of the coil on the fuel pump relay. Initialy, as there is no oil pressure to begin with, the oil pressure switch contacts ar open. The fuel pump relay must get its power via fuse 21 to prime.
    If as you say you don't hear the fuel pump prime when turning the ignition to on, I would be first looking for the ECU signal [+12v] appearing on one side of the relay coil for a couple of seconds. If that's OK, then checking the relay and its connections perhaps.
    Anyway, hopefully the diagram will help you.
    VX II Calais LS1
    Jan 2010
    thanks for the advice so far guys, The problem seems to be getting worse its now cutting out whilst im driving and even after a short trip less than 10km it cut out and wouldnt restart for 5-10mins.
    i disconnected the battery for 5 mins to reset the ecu and it still wouldnt start, no fuel pump priming.
    Im running out of ideas, i will try a new ecu lets hope this will fix it.
    thanks
  16. #16
    delcowizzid's Avatar
    delcowizzid is offline on holiday delcowizzid Senator Signature delcowizzid Senator Signature delcowizzid Senator Signature
    в∞ѕтεכ √&
    Jul 2008
    NZ
    check fuse 10 under the stearing colomn its oil light fuse and efi relay control may not be making good contact
  17. #17
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by delcowizzid View Post
    i checked out fuse number 10 and its not blown and has good contact. I started another thread about changing the ecu and memcal as a fault finding elimination process, could you ckeck it out and give me your opinion please.
    Thanks
  18. #18
    VZ SV6 AND VL CALAIS TURBO
    Jan 2010
    brisbane
    hey mate is it an auto or manual this is just a blow in the wind but if it's and auto sometimes the neutel swicth in the shifter plays up an that and makes it think its in gear when it's not but the motor will turn over but will not have spark or won't let the fuel pump run might be worth changing and cheap to v8 and v6 swicthes are the same
  19. #19
    94 VR Calais V8
    Aug 2007
    Sydney, NSW
    Quote Originally Posted by sus steven View Post
    I don't think that is correct, and if my memory serves me, the motor will not even turn over if the neutral switch is the culprit.
    cheers
  20. #20
    94 VR Calais V8
    Aug 2007
    Sydney, NSW
    thanks
    You said the fuel pump was replaced so I can only assume that the 12V power to the pump is somewhat intermittent. I think this is becoming obvious when you say that you cannot hear it prime again. Did you check with a multimeter as per the circuit diagram I linked to you. When the problem occurs it should be relatively easy to check if the correct voltages are present on or around the fuel pump relay circuit.
    In fact I had a similar intermittent problem that I could not hear the fuel pump being primed. It turned out to be the fuel pump..........BUT to get to that conclusion I first checked that I could see the 12V from the ECU being applied to one side of the the relay coil during the priming cycle.
    Do do this I removed the relay, pushed a small wire into the coil position "G/W" [check the diagram] then pushed the relay back in ontop of the wire so it was held in by the relay. Connected the multimeter between the wire and earth and checked for the 12V appearing for a few seconds after turning the ignition on. Alternativelly just get someone to put their finger on the fuel pump relay and when you turn the ignition on to check if its clicks and stays on for about 3 seconds.
    Satisfied that the fuel pump relay was working I then simply removed the relay, and using a wire shorted out points "V" and "O" in the connector, and presto the fuel pump still didn't work.
    Only thing left was the wire to the fuel pump but it was the pump anyway.
    You should be able to fault find the issue because as you say it stays faulty for a while giving you enough time to investigate.
    cheers
  21. #21
    Dr.304 is offline SuperCharged StatesMan Dr.304 Executive
    1997 VS Statesman Supercharged
    Feb 2007
    Oz
    i found that if you give the car a bit of gas while starting, she starts right up.
    I only tried it like twice, but it seemed like it worked.
+ Reply to Thread
  1. VS wont start!
    By Silver_VS_II in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2009, 05:58 PM
  2. VS V6 Wont start :(
    By skyracer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2009, 10:50 PM
  3. vr 5lt wont hot start
    By wag05n in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 10:04 PM
  4. Need some help...car wont start
    By UN4TOLDVRSS in forum Electrical Wiring / Questions
    Last Post: 05-11-2008, 10:12 PM
  5. VL wont start
    By kapiti holden in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-06-2005, 01:36 PM
