Hey guys, both handles (inside and outside) on my drivers door, decided to not work. I'm not to sure whats going on so I want to get the trim off to have a look. Problem is I cant get it all off with the door open (obviously) so I need to open the door or find a way to get the bastard off. Is there a way I can peel the Top corner down and use a screwdriver or some pliers or someshit?
You should be able to peel away the top right corner with the door closed to some extent...
Oh and you can't get around it aye? You might want to just go to a locksmith bud.
use a steel rule slide it down the outside of the window in line with the lock it may take a bit it will have the same affect as a popper when you shave a car hope this help you
