Results 1 to 9 of 9
Thread: Central locking aerial
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    Default Central locking aerial
    Where is the location of the aerial? Does it run off the same aerial as the radio?
    Cheers.
    VS Berlina 3.8
    Dec 2008
    Does it run off the same aerial as the radio? What aerial are you talking about here. The only aerial I can direct you to is the radio aerial in the front passenger side guard.
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    isnt the sensor for central locking (factory) on the center of the dash?
    dont worry, il start a ride thread soon.
    Kurtp's Avatar
    Aug 2009
    Pakkey VIC
    Quote Originally Posted by hsvpunk View Post
    Not sure, havn't noticed anything aerial like in there.
    RJK: Talking about the receiver for the remote central locking.
    hsvpunk's Avatar
    vy ss II M6
    Jan 2007
    Mornington, Vic
    on the center of your dash it will look like a small button (about the size of a 10c coin)
    I have no idea if vr had it there, but on vs' they are.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I think the aerial that picks up the CL signal is part of the BCM......under the dash above the steering column.
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    I'm pretty sure what you are talking about is the light sensor for the climate control in the higher models, not an aerial.
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    the small black button in the center of the dash is a light detector, in the absence of light (While the car is in acc mode) certain parts of the dash cluster will be illuminated, for instance if you go through a tunnel.
    As Hako has said, the reciever is a part of the BCM, if you are really keen on extending the arial look up the circuit diagrams for your model BCM, they are floating around the internet.
    hsvpunk's Avatar
    vy ss II M6
    Jan 2007
    Mornington, Vic
    hmmmmm, fair enough.
    well that 'absence of light' thingy doesnt do it on my car, nor does it do it on a few other vs' that i know of.
LinkBacks (?)
  1. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  2. Central Locking
    By RoboticCherry-Coke in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2008, 01:13 AM
  3. VP central locking
    By Dazzamcgee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-12-2006, 07:57 PM
  4. Central Locking
    By fatboy2869 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-12-2006, 01:28 AM
  5. VR Central locking
    By mclutterham in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2005, 07:17 PM
