Results 1 to 8 of 8
Thread: vs ss question
    vs ss
    Aug 2009
    reservoir
    Default vs ss question
    do i have to change my computer if i put in a getrag 5spd ive got a 4l60e
    VS SS V8
    Oct 2009
    Townsville, Qld
    Hey bud.
    I think you just need to change your memcal to a manual one... although I've read some people have kept the auto memcal but it screws around with the cars idle.
    There's a thread in the how-to section about doing a manual conversion... have a look thru that and you'll get an idea of what you're up for
    Fenners is offline Fenners
    VS II Berlina Wagon
    Apr 2009
    Boronia
    im pretty sure you do, as the wiring loom has different wires in different pins at the ecu, (eg vs v6 speedo changes from pin d2 to d5 i think) you can either go genuine loom and computer to suit the car with your engine and box or there are people who do patch harness's to convert your auto loom to a mod manual one and then change your memcal.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Theres a few ways i think. Im no expert in any of them. One way is to modify the auto loom and have the memcal re-progammed to suit.
    The other way is to get a maunual g/box wiring harness and install that and then just get your memcal re-proggrammed with a normal manual tune. This i would think is the preffered method.
    Reaper
    VN S1 (was VR) V6 Hilux
    Apr 2009
    The Auto computer is much bigger and has different plugs if it's anything similar to the VR
    VrWagz1's Avatar
    May 2008
    wollongong
    Quote Originally Posted by v6lux View Post
    I have an auto and maunal ecu here and they are both identicle in size look
    Reaper
    vs ss
    Aug 2009
    reservoir
    im going to call up a wreckers or something for vs series 2 ecu cause there the ones that had the getrag for the 5 litre
    VrWagz1's Avatar
    May 2008
    wollongong
    The wreckers will more than likely rip you off for like $200 bucks for the ecu or more. Speak to one of the home tuners on this site and just get them to reprogram your current memcal. If you speak to them, like delco wizz or someone they can also give you some straight advice on what exactly you need to do with the wiring also.
    Reaper
  1. 2 ohm 4 ohm question
    By sweefu in forum Car Audio
    Last Post: 04-05-2009, 05:44 PM
  2. Ebay question.... moral question?? lol
    By NORTI in forum The Pub
    Last Post: 03-04-2007, 03:43 PM
  3. cam question
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2006, 11:27 AM
  4. A VR VS Question for those in the Know
    By Madhouse_Dave in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2005, 04:05 PM
