hey guys, just a quick question. im thinkin of doin the power window conversion. just wondering if the connections for the main loom is already in place or do i have to run it thru myself? same thing for the doors? i've seen sum people said that the wiring is already in the door. if so where r the wires?
most have the wiring on the front doors only if u look in the doors where the loom is goign to you central locking motor u will find a little 2 pin plug taped to the loom most cases the rear the looms arent there but the plug is just forward of the b pillar these looms were cheap from holden not sure if u cans till get them tho and in the center up inder the radio there should be 2 plugs
oh ok, sounds pretty easy to do. may have to source the parts and get crackin. cheers for the info man
