Results 1 to 11 of 11
Thread: Stuffed up when replacing oil pressure switch... HELP
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    Unhappy Stuffed up when replacing oil pressure switch... HELP
    After doing an oil change and replacing the oil pressure switch this arvo i started the car and noticed a small stream of oil coming from the thread of the pressure switch. I tightened the switch up a little more and the housing just broke apart! I'm talking about the thread that the switch screws into.
    What the hell did I do wrong and what am I up for?
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    Mar 2005
    South Coast, NSW
    On closer look it is the 'oil filter adapter' that I've broken. Going to be a pain of a job to replace that
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Must have been cracked before you started Was it leaking oil?
    and 3 Dangerous non ABS VN's
    Mar 2005
    South Coast, NSW
    Wasn't 'leaking' but had a build up of old oil around the connector. Not really any different to any other commodore. Looking at what I'll have to do to replace it it appears I'll have to remove the P.S pump to get acsess to the bolts.
    VP Exec
    Jun 2005
    I don't think that it's all that much of a pain - two bolts and some gasket scraping isn't it?
    The oil pressure switch thread is tapered, I think = wedge action when tightened, breakage if over tightened. Some thread sealing paste - something along the lines of Loctite PST but even 242 is OK - on clean threads will make the seal.
    Mar 2005
    South Coast, NSW
    Cheap6, There's four bolts. Three external and one inside the the oil filter seal. The problem is getting access to two of the bolts, plus sourcing a new or 2nd hand one and a new gasket. On top of that I have to get a lift to work until it's fixed.
    Mar 2005
    South Coast, NSW
    I've ordered a replacement oil filter adapter for $38 including the gasket but some of the bolts look impossible to access. Do I need to remove the power steering pump and there is a curved bracket that looks to be in the way.
    Any advice? I'm hoping I don't have to remove the timing cover just to repair it.
    vs calais
    Dec 2008
    i had a mate, working at holden dealership service,
    he taught me(through his mistake lol) the thread of these doesnt go all the way, otherwise you crack the housing
    i dont think the timing cover has to come off, just gotta get to the bolts
    just out of curiousity, why did you need to replace the oil pressure switch?
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    theres 4 bolts, ones on the inside when you remove the oil filter, also watch for the regulator valve and spring that sits in the gallery
    Mar 2005
    South Coast, NSW
    admir87, you're exactly right. I got the new adapter late this arvo and tonight went out to the garage to check to see I didn't stuff the thread on the new switch. It only screws in about 5 or 6 threads before stopping. I tried the old switch thinking I stuffed the new one and it was the same. Suddenly occured to me I simply tried to screw it in too far. Let this be a lesson.
    I wanted to replace it because I figured the oldone had a slight weep which made a big mess over time. I get them for only about $6 anyway. All my parts I get for cost price plus 5%.
    vs calais
    Dec 2008
    Default reply
    Quote Originally Posted by Scooter79 View Post
    6 dollars is cheap!!!
    ye sorta same deal here, gotta love knowing someone in Holden parts
    btw nice super6 calais, will be getting one myself hopefully soon
  1. Replacing Oil Pressure Sensor
    By tepaus in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-11-2011, 09:46 PM
  2. oil pressure switch
    By strparker in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-08-2009, 12:21 PM
  3. Replacing oil switch (ebay one) and replacing cup holders???
    By BlackCaprice in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-06-2009, 03:50 PM
  4. VX Oil pressure switch
    By justapeeper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-08-2008, 09:43 PM
  5. Oil Pressure Switch
    By Holmez in forum V8 Development and Modification
    Last Post: 10-10-2007, 03:52 PM
