Results 1 to 10 of 10
Thread: Question about VR V6 PCM
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Default Question about VR V6 PCM
    Is the VR V6 PCM compatible with dyno tuning? I know it can be reflashed with a new program while out of the car, but Im not sure if this would be a pissabout and added expense when dyno tuning. Would it be easier if I just got an aftermarket ECU, like a link or something? Suspect the car to be leaning out at WOT because of the funny heads and rockers fitted
    VN S1 (was VR) V6 Hilux
    Apr 2009
    If you are talking about the Factory ECM, then no, it is read only.
    In saying that, I don't know what a PCM is, so someone correct me if I'm wrong.
    Jan 2008
    vs v6 turbo, vn v8 turbo
    May 2009
    tearoha nz
    yes it can be programmed in realtime delcowizzid tuned my v6 turbo with the factory vr ecu with slight internal mods
    Apr 2009
    Quote Originally Posted by plymouth_hemi_69 View Post
    Interesting. Perhaps they used a VS Module, as I hear their parameters can be altered live or on the fly? Is it true for the VS?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i use these and some custom bin files also on that site in the custom code section for free has all xdf's and adx files for tuning and logging can auto tune the fuel table while you drive as well all sorts of little goodies vr auto code is a we way away ive tested an early version allready works great.
    delcohacking.net • View topic - FS: NVRAM ECM Conversion
    delcohacking.net • View topic - FS: '808 RS232 Communications Boards
    you can always get a kalmaker equipped workshop to tune the ecu realtime then burn you a memcal when its finished
    Jan 2008
    Quote Originally Posted by delcowizzid View Post
    Want to use my car as a guinea pig? il pay you for the work you do, and you can have it as long as you like (dont need it for work or anything).
    в∞ѕтεכ √&
    Jul 2008
    NZ
    what heads and rockers does it have
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i see you in wellys now can soon come round and tune it while you drive when i get home
    Jan 2008
    Wont be bringing the car down till next week, will arrange it then if you are keen?
    I was gonna bring it back down last weekend, but found it was getting hot at anything over about 20% throttle - i was worried it would cook itsself if it went closed loop and tried to lean out any more.
    It has yella terra roller rockers, I dont know the ratio (YT cant/wont tell me) but the part number is YT6306. I dont know much at all about the heads, other than that they are off a VN and were on a stockcar before i got them. The valves are a few MM larger than stock (cant find where I recorded exact size) and the intake and exhaust ports have been ground out to match the intake and exhaust manifolds.
    Sorry about having such little info on them.
  1. Help with this question please
    By kizza_VL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2008, 07:56 PM
  2. Help...Tap and Die question
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2008, 10:02 PM
  3. Ebay question.... moral question?? lol
    By NORTI in forum The Pub
    Last Post: 03-04-2007, 03:43 PM
  4. Question
    By wbmagnum in forum General Discussion
    Last Post: 03-11-2005, 07:36 PM
