Results 1 to 10 of 10
Thread: Vr stalling and weird acceleration
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    Default Vr stalling and weird acceleration
    93 vr constant stalling, fuel pump, injectors, oil and filter, O2 sensor, no vacuum leaks, IAC motor changed. What can it be? Sometimes only happens when just started and go to break and it downshifts and it feels like it is going to stall. Other times works absolutley fine.
    Mar 2009
    VN S1 (was VR) V6 Hilux
    Apr 2009
    Have you tried a swap of the DFM and coils?
    Other than that, this sounds a loose wire or some vibration related issue in a plug - corroded pins, wires shorting?
    Just a thought -
    How about the Knock Sensor? A lot of engine noise will trigger the ECU to kill the fuel momentarily!
    VZ SV6 AND VL CALAIS TURBO
    Jan 2010
    brisbane
    hey mate i would put my money on the crank angle senor thats causes you car to stall and play up it's about $60 and is behind the balancer
    vr statesman 5.0
    Jan 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    +1 on TPS. If it downshifts in gears, its a sign it thinks the throttle is more open than it is, also why it thinks its getting more air but isnt, and it stalls because of this. Replace the sensor before you waste money on anything else.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    base idle setting to low ??? has the idle screw been played with ??? checked your fuel pressure reg for fuel in the vacum line ???
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Crank angle sensor is my bet.
    TPS, knock sensors etc usually just log a code.
    Deneo's Avatar
    Deneo is offline Lock your Daughters up
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    +2 For the TPS, Just replaced mine today, fixed the problem. $85 genuine from holden.
    Edit: Will show up Code 19 if it's playing up.
  1. VN has no acceleration
    By snowbeast in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2010, 05:51 PM
  2. Acceleration Lag
    By thebulk in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-05-2009, 04:57 PM
  3. Help! need help with acceleration!
    By fatboy15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2008, 10:18 AM
  4. Acceleration on VT
    By HamaTime™ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2008, 09:43 PM
  5. bad acceleration
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2005, 04:23 PM
