Results 1 to 15 of 15
Thread: VS Battery, Starter or Something else?
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    Default VS Battery, Starter or Something else?
    hey guys
    just a question, I have a small problem every-time I try and start the VS it drags it ass as if the battery is flat, yet it does start eventually until today, so luckily my neighbor is a mechanic and gave me a jump, then it started faster then it ever has before and the multi-meter gave a charge of 14.0 when it was running but when off went down into the twelves, does this sound more like the battery or could it be a malfunction starter pulling too much current?
    Thanks
    VY SS
    Jun 2006
    Albany
    if it starts straight away when jump starting the yes it probably is the battery, do you know how old the battery is?
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    the battery isn't that old apparently, and indicates it is charged but neighbor said, may not have enough cranking amps.
    VP SS
    Jan 2008
    Hiding in WA somewhere
    could be a shagged alternator
    If its got Wheels or Boobs its gonna cost ya money
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    yeah, I am guessing he is as he checked the charge when it was running and alternator was charging @ 14 volts, and on Saturday when I picked it up I Drove it over 100KM and it never stalled once going from loosing charge, just don't seem to hold it when engine is off.
    VY SS
    Jun 2006
    Albany
    if you are really unsure maybe just get your battery load tested, also what did you use to see how charged it was? if you used a multimeter then that doesnt tell you how charged it is, you will need to use a hydrometer.
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    VY SS
    Jun 2006
    Albany
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    K, think I will go down to a Mechanic tomorrow and have the problem pin pointed once and for all.
    Thanks for the help guys.
    VY SS
    Jun 2006
    Albany
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Check for a fried wire at the B+ (main wire to battery) terminal of the alternator. This messes with the charge rate.
    Also make sure the nut on starter solenoid is tight. The one at the end of the main battery cable.
    Both VERY common faults....
    ......assuming the battery is OK.
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
  15. #15
    '98 vt berlina
    Feb 2010
    hsv91ss, did you have the problem looked at yet? what was the cause?
  1. Battery or starter
    By Rumbl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2009, 09:03 PM
  2. Starter motor or Battery
    By Legs in forum General
    Last Post: 27-06-2009, 07:29 PM
  3. Battery, Alternator or Starter Motor?
    By mischa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2008, 09:59 AM
  4. Alternator or Starter motor or battery Problem HELP!!!
    By commo69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2008, 07:10 PM
  5. Replies: 1
    Last Post: 17-01-2005, 05:39 PM
