i bought a new head unit and now my aerial up and down buttons are not working its all wired up right is there anything i can do to by pass the head unit
There is a wire that sends the signal to the aerial. On your new head unit you might've had a wire called "Power Antennae" and on Kenwood stereos this is a blue wire. It sends a signal to the BCM and then the BCM controls the Power Antennae.
When it doesn't receive a signal, it's always in the "down" position meaning it'll always return back to down if you press the up button.
You didn't mention it, but I'm assuming your car is a high end bcm meaning it's a Berlina, Calais or Statesman.
I've only got an executive with a low end bcm but I upgraded the power antennae on my car to an electric one using the power antennae and power antennae module from a VP Calais to bypass changing the bcm.
To bypass your head unit (if it's missing a power antennae wire) you hook the wire used to signal an amplifer instead. This is an external 12V+ wire.
checkout myVS S1 Wagon here!
good guess its a Berlina yer i think the motor might have just shit it self oh well i did hook to the bule wire but i will do a few more test before i have to rip it out
Power is measured in DECIBEL
yer i found fount what was worng the arial was snaped and right at the bottom
MY RIDE
