Was thinking about getting my VS 5L statey converted to manual. Any body done it or know where i can get it done in vic, near Geelong would be good.
I think CRS does it but lookin closer to home.
Would have a go myself but its my everydayer and shed is full of project already
I think these use a different speedo in the cluster, I can't remember but there's auto clusters and manual clusters, then there's v8 clusters. Someone might correct me on this.
You'd also need to get hold of the clutch pedal, clutch assembly, etc otherwise they are gonna charge you a million bucks. Do the research first, find out what you need, then get the mechanic to put it together.
checkout myVS S1 Wagon here!
you can use your standard cluster, just gotta wire it up is all....just buy a conversion (allow for 1-2k limit) should be able to do it in a day if your motivated. not hard at all.
