Results 1 to 4 of 4
Thread: Could a leaking exhaust manifold damage or give false readings from a O2 sensor?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default Could a leaking exhaust manifold damage or give false readings from a O2 sensor?
    The car (S/C V6 VS) has had a leaking manifold for a couple of months now, but not to bad i can hear it with the window down. Now the car studders when cold on half way throttle when cold and i only replaced the O2 sensors about a year ago (4 WIRE) and it comes up with the same codes as last time this happened Code 44 - RH Oxygen Sensor Lean (O2) .
    VXII
    Nov 2009
    A leaking exhaust manifold will most definitely affect the readings of an oxygen sensor. After the exhaust valve closes, a low pressure is created behind the exhaust charge in the the manifold, and this is where extra oxygen is sucked in.
    It won't, however, affect the driveability of the car any more than very very slightly. Oxygen sensors are only trimming sensors, and the engine can run perfectly fine without them, which is what happens when a fault code shows - the ECU disregards the signal and substitutes its own.
    vs caprice
    Feb 2010
    I've just replaced a cracked exhaust manifold which I found when I got the ever faithful engine light error. The errors were 64 - lean reading & 76 - uneven fuel mixture between left & right banks. I though the new manifold would stop the error but I'm still getting the errors. I've just checked the pasenger (left) sensor & I was absolutley coated with so much soot I couldn't see the flutes in the tip. Cleaned it it a bit but still getting the error.
    Any ideas anyone
    VS executive
    Jun 2009
    probably just bang in a couple of new ones, i just did mine and they `looked` fine but fuel consumption allmost halfed.
  1. Temp Gauge Giving False Readings
    By Chirpstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2009, 08:24 AM
  2. rebuilt motor and have coolent leaking out of the exhaust manifold help plz
    By BENJAMUM in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-05-2009, 09:50 PM
  3. 1991 vn speedo giving false readings
    By arc angel vn ss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2009, 07:07 PM
  4. Leaking Inlet Manifold - v8
    By VS 5.0 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2006, 09:05 PM
  5. Leaking exhaust manifold
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 07:41 PM
