Results 1 to 24 of 24
Thread: THAT annoying rattling sound @ idle
    VS Exec Series II
    Jan 2005
    Ringwood, VIC
    Default THAT annoying rattling sound @ idle
    Hey guys,
    This may have been covered before, but I tried searching and just ended with about a trillion results, so figured this was the most direct route to an answer!
    I'm sure most of you will know the rattling sound I'm talking about. It seems VERY common on the Ecotec motors. When ever I'm pulled up at lights and I hear it I know a vs or vt is nearby.
    It only happens when I'm in drive with my foot on the brake, so the engine is under a slight amount of load. When I put it back into Park or Neutral the sound goes away.
    I'm certain it has to do with the timing belt or a pulley, as I once quizzed my mechanic about it, and he just sprayed some silicon spray somewhere and it fixed it for about a week.
    Is there a more permanent solution?
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    I had the same thing in my VR. Older motor sure but not much difference. Turned out idler pulley was cactus. Check it next time the car is running if the tensioner jumps around when idling it needs to be replaced. I know it only does it in drive but don't forgot that in drive the car idles lower.
    VS executive
    Jun 2009
    i had my dad look at that the other day , hes been a mechanic ( as a hobby ) since he first started driving and he couldnt find it but said it was nothing too worry about.
    my car does it in park aswell.
    VS Commodore Ute
    Nov 2009
    the common rattling noise in ecotecs is the tappets isnt it? however doesnt explain y silicon would fis the noise...
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    mine doesnt have any noises on idle
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    My VR has rattle, but goes away when the air con is running. I am sure it is the compressor.
    Might be the same for the VS?
    VN Wagon
    Jan 2010
    The rattling could also be cause buy a engine mount thats maybe why it only happens under load. The mounts can look completey fine from the outside buy can be collapsed inside. Fixed the problem in my car, hope this helps
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the noise went away after spraying with silicone it indicates he sprayed one of the idler pulleys or the tensioner pulley. They all fail eventually and the best thing you can do (for peace of mind) is to remove the serpentine belt and then spin each pulley by hand...any pulleys that are rough should be replaced very soon because if they fail, the belt will be thrown and you will have no A/C power steering, waterpump or alternator.
    eXphoid's Avatar
    eXphoid is offline I have no license yet xD.
    VZ executive & VS Equipe S2 Ecotec
    Dec 2008
    VIC
    The rattling stops when I put it in neutral at the lights =]
    My 1997 VS S2 Equipe [First Car]
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by eXphoid View Post
    You may have a sheared engine mount - when in D and stationary, there is a load placed on the engine which makes it rotate to one side....like it's in tension - if a mount is sheared it can move about and make a noise. This can also place strain on the exhaust headers/downpipes which then rattle.
    Take it out of D and into N and the engine has no load on it and sits squarely in the mounts....no rattles.
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    gear box mount if its an auto they do the rear centre mount and rattle like poo but the pulleys rattle 2 the one for a vn bolt on the vr and probably yours too but they have a servicable bearing (and are chrome - bling)
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    vn vp vr is normally timing chain or tensioner vn S1 especially they snap right off and fall in the sump leaving the chain slapping round.other common rattle is the balance shaft bearings and gears
    VS Exec
    Jan 2007
    Adelaide (South)
    the water pump makes a bad rattle when the bearings are fagged, which is also a common problem.
    VS Exec Series II
    Jan 2005
    Ringwood, VIC
    So many different causes of rattles. lol. This rattle i'm talkin about is VERY distinctive...and i know is a VERY COMMON problem. I hear it all the time when stopped at traffic lights or when banked up in the city. Surely there would just be one simple thing to replace/tighten to fix it?
  15. #15
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Bob129 View Post
    If only life was that simple.......Commodores are the same, there ain't no simple fix unless you identify the cause. Have you checked all the suggestions and eliminated them?
  16. #16
    VS Exec Series II
    Jan 2005
    Ringwood, VIC
    Ok, so i've finally got around to sorting out this rattling sound. Hopefully it helps other people, as it is a very simple fix. All i hard to do was go down and purchase a can of silicone spray from Supercheap auto, and then spray it onto my fan belt until the noise stopped. I dunno how long this fix will last, but its been 4 days and the noise has returned, so im quite happy with the outcome!
  17. #17
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Do you have a plastic idler pulley?
    Visit my Facebook page
  18. #18
    VS Exec Series II
    Jan 2005
    Ringwood, VIC
  19. #19
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    mine has that ratteling noise when in drive and turning corners slowly, is that what ur symptons were too? doesnt do it in park of netural
  20. #20
    VS Exec Series II
    Jan 2005
    Ringwood, VIC
    nope, your problem sounds completely different to what mine was. Your's mite be related to the power steering?
  21. #21
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    oh ok well i just put some wd40 on my pulleys and it seemed to have stopped the noise
  22. #22
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Quote Originally Posted by hako View Post
    +1 first thing to do IMO because its quick and easy.
  23. #23
    vn exec
    Sep 2010
    launceston
    I HAVE THE SAME PROB IN MY VN i KNW IT'S OLD BUT IT REALLY SOUNDS LIKE THE TAPPETS AND GIVE'S ME THE IRRATES IF ANYONE HAS A SOLUTION PLEASE !!!!!
  24. #24
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Just try the fixes mentioned above - do the easy one first - spray the pulley bearings with WD40/RP7/silcone spray. Keep your hands away from moving parts!
  1. rattling sound at slow speed...
    By lumina01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-01-2010, 10:44 AM
  2. loud rattling sound from vr auto
    By 94calais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2009, 04:55 PM
  3. rattling squeaking sound
    By vn88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-01-2009, 09:02 PM
  4. Rattling VN V6, very annoying!!
    By 3.8L of executive power!! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2007, 02:28 PM
  5. knocking rattling sound
    By krisjanik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2006, 05:21 PM
