Results 1 to 8 of 8
Thread: Snapped thermostat housing bolt
    VS Acclaim V6 Wagon and VT Exec V6 Wagon
    Jan 2006
    Default Snapped thermostat housing bolt
    I thought I'd share this little experience I had not long ago when attempting to replace the thermostat in my VS V6.
    One of the bolts (size M8) snapped off when trying to undo it. After a few hours of trying to extract the half that remained (unsuccessfully... I even managed to 'weld' a drill bit into the bolt) I decided to change my plan of attack…
    The result:
    I drilled and tapped the new M5 holes either side of the original, which I ground down to be flush with the surface. I filled in the hole in the thermostat housing with metal putty (looks like a stick of liquorice) and have used fibre washers with the M5s to help seal the holes. This has been performing perfectly fine for 18 months now.
    Lesson 1 – make sure the bolts are cold when you try to remove them, and it probably wouldn’t hurt to spray some WD40 on it the night before.
    Lesson 2 – replace your original bolts next time you change the thermostat, they are M8 x 25mm.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    That's a great fix....I probably would have drilled it out just as you tried and failed. More than one way to skin a cat!
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    did you try an easy out?
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    Jan 2006
    Quote Originally Posted by ScoHar View Post
    I sure did, but in order to do that you need to drill a hole in the bolt first, and the drill bits kept snapping. Finally one of them snapped and welded itself into the bolt.
    VP SS
    Jan 2008
    Hiding in WA somewhere
    so you still havent changed the thermostat though
    If its got Wheels or Boobs its gonna cost ya money
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by excalibur View Post
    Maybe he has - looks like a new gasket and the bolt looks new???
    Last time I tried an "easy-out" it snapped in the bolt hole - that was it for me - I slammed the bonnet down and traded it next day.
    Jan 2006
    Yeah I definitely changed the thermostat and gasket. I just changed it again last week (18 months later) as it didn't seem to opening soon enough. Turns out the heater tap was cracked so there was an air bubble in the system and I was losing fluid. $45 for a new tap by the way. All good!
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Spark Eroder would prob best the next best thing.
  1. Thermostat Housing
    By OSL-060 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2009, 07:58 PM
  2. vr commodore manual-snapped the housing around the tailshaft connector to gearbox
    By ital355stroker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2008, 09:11 PM
  3. HELLP Thermostat housing snapped.. Where can i get a new one and how much ?
    By JustVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2008, 06:53 AM
  4. Thermostat Housing.
    By eXcon in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-05-2008, 06:54 PM
  5. thermostat housing
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2006, 09:26 PM
