Results 1 to 8 of 8
Thread: Code 21 @ WOT
    VR Clubsport
    Dec 2005
    Exclamation Code 21 @ WOT
    hi, my tps is logging code 21 when i give the car a hit WOT, i have checked the sensors resistance making sure the contact from closed throttle to full throttle is a consistent ascending reading which it is.
    my question is what resistance values should i see on a 20k scale at closed and WOT on my 5 litre as i may need to reposition it due to having an aftermarket manifold?
    cheers
    VR Clubsport
    Dec 2005
    EDIT: i put a multimeter on it to check voltages now and i have the following figures:
    closed throttle = 1.1v (prob coz i have my car throttle screw adjusted a lil high to compensate for the big cam)
    Wide throttle = 4.8v
    i am now stumped as to why code 21 has appeared as i thought these voltages were acceptable, can anyone help please
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try resetting the ECU by removing the negative battery terminal for 30 seconds. Then after a day or so run the codes again. It may just be a simple glitch.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    should be like 0.5 volts closed throttle
    VR Clubsport
    Dec 2005
    tried disconnecting my battery no luck. Delco my closed voltage would read higher than normal because my throttle stop screw is allowing my throttle to be a lil open to raise my idle rpm due to my cam.
    im only worried that WOT i have tested it to be 4.8v but still it flicks the check engine light on when i go WOT and shows code 21, this is within spec isnt it???
    в∞ѕтεכ √&
    Jul 2008
    NZ
    its probably getting confused all due to the idle screw being in too far it zero's itself at key on but with it so high at closed throttle its gonna be wondering whats going on
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    I think 4.8v is too high for full throttle. From memory I think it is supposed to be below 4.6v at WOT.
    muttley383
    VR Clubsport
    Dec 2005
    oh ok thanks guys, i might elongate the screw holes and see if i can adjust the position to giv it a false reading, cheers
  1. code 66 on VR
    By mish22 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2010, 07:05 PM
  2. Code 72 - Vehicle Speed Sensor (VSS) and Code 73 - Pressure Control Solenoid Current
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 04:39 PM
  3. code 12 and 13
    By itchy pits in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2005, 03:15 PM
  4. Code 21
    By Terfade in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2005, 08:36 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
