Results 1 to 5 of 5
Thread: hand brake on vr wagon
    Mar 2008
    Default hand brake on vr wagon
    Hi
    I just got a vr wagon and the hand brake doesnt work
    the cable is there from the adjuster back to the rear wheels, but i cant get right under it to have a good look
    im guessing there is another cable that runs from the hand brake lever to the adjuster, does nayone have any pics of it or should i pull out the console and get to the hand brake lever that way
    cheers
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Have a look underneath first - it's possible the cable has stretched. Easiest and safety way to look under is drive one wheel onto a gutter.
    Mar 2008
    thanks Hako
    will try it on the gutter and see what it looks like
    from the hand brake lever to the adjusting thread and nut is there a cable between them or something else
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It's actually a steel rod that goes from the handbrake to the cables that go to the back brakes...the rod is threaded and it can be adjusted from there, however if you have no handbrake you will really need to remove the back discs/drums and make sure you have some brake shoe friction material left. Also to do a proper job you need to adjust the shoes at the rear drums first and then do a final adjust at the steel rod adjuster previously mentioned.
    If you want to PM me your email address I can scan the instructions and send them to you.
    ps...Toowoomba swap meet is on tomorrow so if you need the scans I probably can do them in the afternoon after I go to the swap
    Mar 2008
    hi hako
    thanks for the help mate
    i didnt know it was an steel rod from the hand brake lever to the adjuster, thought maybe had a cable that had snapped, my hand brake was pulling all the way up and done nothing
    adjusted it up and it seems fine now
    thanks again
  1. Hand brake
    By nuradh in forum General
    Last Post: 11-08-2009, 12:23 AM
  2. Help with hand-brake
    By Tyson23 in forum General
    Last Post: 28-12-2008, 07:51 PM
  3. Hand Brake stuffed
    By VSTrev in forum VE Holden Commodore (2006 - ?)
    Last Post: 16-10-2008, 04:22 PM
  4. VY Hand brake adjustment
    By R-ON in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-09-2006, 08:50 PM
  5. hand brake
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2004, 07:26 PM
