Hey can anyone tell me how to change light bulbs in dash under the auto gear shift to make them light up again? i checked the fuses nothin blown there so i guessed it would be some sort of litle light bulb. its in a vs ss by teh way.
Also are fog light bulbs hard to change in a vs ss?
cheers
mines manual so dont have any tranny lights, however im assuming its the same as the exec, my previous car was an VS exec, the light under the tranny shift its a little blub u can get to by simply removing the ash tray and popping off the cover (you may have to disconnect the lighter), remove the drive letter cover and under than you will see a little blub.
Not sure about the foggies, havent had to change mine.
It isnt all that tricky, if you get stuck get in touch with me and ill put some pics up with instructions. Basically u open the ash tray and pull it and it will come out. You can then lift the console bit, you should be able to see where you need to remove wires and screws. Just play you will find it easy, good luck
cheers changed the little bulb today. was easy to do as u said.. thanks for the help
what type of bulb is it? i think mine is dead?
i got to it today but it cant come off, but it have a brow/white wire and for memory i think a black one too, any help?
There is no such thing as death, life is only a dream, and we are the imagination of ourselves.
T5 bulb, grab the head with pliers, it is pretty tight just don't squeeze so hard you break the glass.
Btw there is a complete guide on how to change every interior bulb on the vs. And btw this thread is 6 years old.
Be patient, I am inquisitive and I am learning.
Lol. . . One of the best digs ive seen in ages!
haha im a newb man, signed up last night
