Results 1 to 3 of 3
Thread: How To Fix Fault Codes 32 and 97
    VS Ute
    Feb 2010
    Wollongong, NSW
    Default How To Fix Fault Codes 32 and 97
    I've just run a fault code test on my VS ute and it came up with 32 (Manifold Air Flow Sensor) and 97 (Canister Purge Solenoid and/or /Circuit). I was wondering if anyone could let me know how to fix these problems. I'd like to learn how to do it myself.
    Also, when accelerating there is no power and sounds like its running on 5 cylinders until the revs finally get up then it kicks in like normal. I haven't checked the plugs but was wondering if this would be because of the fault codes I'm getting.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like you may have a vacuum hose off somewhere - look carefully aroung the charcoal canister where the vacuum hoses attach and also around the throttle body - you may need to remove the engine cover to check all the hoses. Make sure they are not split or pulled off.
    If a hose is off/split it can cause the problems you describe.
    And welcome to the forum.
    VS Ute
    Feb 2010
    Wollongong, NSW
    Thanks heaps ill have a look. And cheers for the welcome
  1. Fault codes 15-16
    By Matt_vp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2006, 07:43 PM
  2. Fault Codes 23 and 32 HELP
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2006, 06:39 AM
  3. fault codes
    By timboco in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2006, 03:51 AM
  4. fault codes!
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2006, 06:23 PM
  5. fault codes
    By timboco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2006, 07:24 AM
Tags for this Thread
