Results 1 to 6 of 6
Thread: [Buick motor] Valley cover coolant leak
    VR Series 1 sedan
    Jan 2010
    Default [Buick motor] Valley cover coolant leak
    hey all
    as in the title, ive got a VR with the buick motor, i had a leak a while ago on the bypass hose so i fixed it and my system has built pressure again, but today i was just checking it over and ive now noticed ive got water leaking straight out of the valley cover bolts on the front of the motor, seems only the first 2 (the one below the thermostat and one under the alternator)
    im yet to see if its just needing to be tightened, however with my history with toyota motors it makes me think that my valley cover gaskets bay be buggered and getting past the seals and therefor leaking thru the screw threads
    am i on the right page here or is there other issues that can come up with these motors?
    cheers
    My Rides.....
    1994 Holden Commodore VR sedan - my 2nd VR Click here for Members Ride!
    1988 Toyota Supra Ga70 - The Daily skid machine
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    I don't know what differences there are between the VR buicks and the VP buicks but I know the valley gaskets on the VPs are prone to developing leaks around the water channels.
    You dont want to overtighten it either as I did this the first time I changed one and it damaged one of the thick rubber seals so I had to do it all again .
    If the bolts are all at the right torque settings then I dare say the gaskets will need replacing.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    VN S1 (was VR) V6 Hilux
    Apr 2009
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    last ones i bought wernt much 30 bucks or so for the whole set both sides front and rear and new throttlebody gaskets
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    yeah mine were about the same as delco's, which is good because i had to buy them twice
    Although mine didn't come with the TB gaskets but i just made my own.
    1. 1990 VN Exec V6
    VR Series 1 sedan
    Jan 2010
    yeah i know their fair cheaper than they use to be, i just wanted and 2nd opionion as i dont remember the gasket going around the bolts but i dont doubt they would, well it seems im going to be do that next weekend
    cheers fellas
    My Rides.....
  1. Is it hard to change my valley cover and rocket cover gaskets
    By eagle13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2010, 09:39 PM
  2. does a vn valley cover fit a vr 3.8 v6
    By peckzz in forum General
    Last Post: 23-02-2010, 08:33 PM
  3. 308 Coolant leaking into Valley
    By NZVK308 in forum V8 Development and Modification
    Last Post: 17-12-2009, 08:24 PM
  4. Valley cover gasket!!
    By AttaBoy in forum General
    Last Post: 17-06-2008, 09:41 PM
  5. Valley Cover Leak
    By f_vos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-05-2008, 04:18 PM
