Results 1 to 8 of 8
Thread: clutch pedal vibration
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Default clutch pedal vibration
    Has anyone had their v6 t5 equiped vr or vs suddenly make some clutch squealing noises and develop a vibration through the pedal but only when the engine is running...engine off no vibration clutch seems normal?.....Im thinking broken pressure plate fingers or dud throwout bearing? I gave it a little boot from a standing start (didnt drop it) and while it took off ok it made a little clunking noise....I noticed the noise and vibration after that Clutch is 4 years old and was a repco unit....the clutch itself actually works fine
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Sounds like a busted pressure plate.
    Get an Exedy one next time.
    Nov 2003
    northside brisbane
    Quote Originally Posted by RX25SE View Post
    I was leaning towards them ...do you reckon the excedy is superior? and in what way?
    Nov 2003
    northside brisbane
    Ok put in the excedy ,replaced spigot bush looked all good...pressure plate fingers were worn where the throwout was running against it...squeal was the throwout bearing outer surface that doesnt spin running against fingers .No shutter but the vibration is still there...nowhere as bad but just annoying....im leaning towards the front bearing retainer snout surface which was worn on one edge maybe allowing the throwout bearing to move a bit and vibrating through the pedal....the bloke at the gearbox place said it was ok but im not sure now...any ideas?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Did you get your flywheel machined?
    Visit my Facebook page
    Vr exec 5.0L 5speed
    Mar 2008
    Quote Originally Posted by markovr View Post
    I've found that a bit of vibration through the pedal is normal on a new clutch until the throwout bearing wears into the PP fingers a bit. Also did they replace the little vibration dampers that support the throwout bearing ?
    Nov 2003
    northside brisbane
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Yes got it machined and the actual clutch operation is fine ...no shutter...and smooth on take up just the vibration that the cable is putting on the pedal just as you push it in ...it actually gives the brake pedal a litttle vibration if you have your foot off the clutch pedal.
    The bearing retainer and snout on the front of the gearbox was worn ..like I said in the post above it might be causing the throwout bearing to move enough at light clutch pressures to vibrate enough to send it back to the pedal...I was just wondering if anyone else has found this? Car has a over 300 on the clock and has a few noises but it goes ok...just love to track this down as Im sure im not alone.
    Nov 2003
    northside brisbane
    Asked this question to a company up in queensland that specialises in these gearboxes and he said it will be the bearing retainer like I thought and also I should use a better throwout bearing with a steel carrier(not plastic) ...anyone used the different type of throwout bearing? The retainer is a exchange job so I am assuming they machine or press out the old worn piece and press the new in .Anyone had this done?
  1. Clutch pedal spring
    By dawg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2011, 05:12 PM
  2. Clutch pedal problem!
    By johnvncommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2009, 10:19 PM
  3. t5 clutch pedal again
    By VSEXEC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 07:28 PM
  4. Wtb:vs Clutch Pedal
    By janhdt in forum Swap / Wanted to Buy / Trade
    Last Post: 25-11-2007, 12:43 PM
  5. VR Clutch Pedal Vibrations
    By MuNtEd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2004, 08:35 PM
