when i turn right a high pitched squeeling noise occurs, usually happens when travelling about 15-25 kms. its very annoing and a little embarrasing. has anyone had this problem and fixed it?
It could be your drive belt slipping. As you turn the steering the power steering pump becomes harder to turn. There might be a problem with your steering causing the pump to be harder on right hand turns. I think there are markings on the tensioner arm to indicate if your belt needs replacing.
MY RIDE
