Results 1 to 7 of 7
Thread: VS Commodore Sensor Problems ???
    VS Series 2 1996
    Feb 2010
    Question VS Commodore Sensor Problems ???
    Hi, i am new to this site. I am wanting to know if anyone can help me.
    I am having Problems with my VS Commodore.
    A few weeks ago my Fan Belt snapped and wrapped around the bottom Pulley, which snapped the crank angle sensor and destroyed the bottom pulley.
    I replaced the Fan Belt, Bottom Pulley, and Crank angle sensor. Since doing that i have been having troubles with the car stalling at lights, and when it does stall it starts straight away, and also it is miss firing.
    This morning i have done the check on the error codes, and i am getting Code 47.
    When i brought the Crank angle Sensor, it was new in the packet. Is it possible i have brought a faulty 1 ???
    Thanks Steven.
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    possible yes. also possible that in destroying the sensor the belt also wiped out the wiring, which would present the same issues
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    VS Series 2 1996
    Feb 2010
    I checked the wiring and all seems to be good. Do you think it could have something to do with the Coil Pack?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Also check you have the correct balancer pulley for your engine number/VIN.
    Edit....series 1 and series 2 VS models have a different harmonic balancer.
    vs commodore
    Oct 2009
    Tamworth NSW
    Disconnect the battery for a couple of minutes to clear any logged codes.See if that makes any difference.
    VS Series 2 1996
    Feb 2010
    vs commodore
    Oct 2009
    Tamworth NSW
    Did you sort out the sensor and error code problems?
  1. map sensor problems
    By ke303800 in forum General Discussion
    Last Post: 04-08-2009, 04:06 PM
  2. Crank Angle Sensor Problems
    By Bex in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2009, 06:10 AM
  3. VS Ute O2 Sensor problems
    By was_03 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-07-2009, 04:01 PM
  4. Ambient temperature sensor problems
    By aceventura in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2009, 09:13 PM
  5. Oxygen Sensor and other problems
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2005, 12:06 PM
Tags for this Thread
