Results 1 to 5 of 5
Thread: vs executive 95 radiator
    none yet
    Feb 2010
    Default vs executive 95 radiator
    hey, my friends brother is selling his old car a vs executive 95 model the only thing wrong with it is the radiator it heats up to quick, just wanna know roughly how much that will cost (im not really car smart) !
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by suffa View Post
    Welcome to the forums.
    Your going to have to get a little bit more info for us to help you out though. The radiator doesn't really "do" anything. It's pretty much just something that sits at the front of the engine bay, the engine heats the coolant, and the coolant is passed through the radiator. The metal fins transfer the temperature of the cooler air that passes through it to the coolant. Really the only thing that can go wrong with a radiator is a leakage somewhere. So I doubt it's your radiator. To answer your question though, I bought a brand new radiator from eBay for $130 and fitted it myself.
    When you say "heats up too quick", do you mean when you read the temperature guage, or when you put your hand on it?
    none yet
    Feb 2010
    yes the tempreture gauge heats up really quick? so that would mean the radiators leaking?
    im just wondering if i should buy the car and then fix up this problem then it will be driveable the cars $500
    VS Berlina 3.8
    Dec 2008
    No, your radiator leaking won't really have an effect on temperature. I'd be looking at the thermostat. Also where does it sit on the temperatur guage and how fast does it get there?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My personal advice for what it's worth is ....don't buy a car with known problems if you have no mechanical knowledge. You will be so browned off with the car breaking down continually that you will hate cars period. Plenty of good cheap ones out there. Good Luck.
  1. Radiator VN serie 2 (radiator cap) on a serie 1 (no raidator cap) ?
    By zai in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2009, 12:07 PM
  2. changing VN S1 radiator to VN S2 radiator
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2009, 06:30 PM
  3. HD Radiator How to tell
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2007, 12:13 PM
  4. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
