Results 1 to 2 of 2
Thread: Check engine warning light
    vs series 3 ute
    Jan 2010
    Default Check engine warning light
    I had the orange engine error light coming on .I had it checked and it ended up being the oxy sensors. I m going to change them myself they seem basic enough. Will this automatically stop the warning light when the problem is fixed or is there some other bs I have to do to reset it ?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If the light remains on after changing the oxygen sensors then disconnect the battery for about a minute and that will reset it. If you have the stock radio fitted you will need to enter the security coded when the battery is reconnected.
    MY RIDE
  1. Check Powertrain Warning Light
    By allanthompson in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-09-2009, 09:22 AM
  2. Check Enigine warning light.
    By Tiger28 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-04-2009, 10:46 AM
  3. Airbag warning light after headers install and brake check??
    By Curtisb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2009, 12:07 AM
  4. Check engine Warning
    By Joshua in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-09-2008, 11:42 AM
  5. Check engine warning
    By liberator81 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-12-2005, 12:36 AM
