Hi Guys
I have a VS 96 executive.
I just got the air con re-gassed & the condensor replaced & also a pipe.
When the air con is on in the car on fan speed 2 the air comes out cool yet if i use it on fan speed 3 or higher it blows out heaps warm air
Does anyone have any suggestions to this?
Emma
It's possible your heater tap is not turning off with the result you are mixing hot air with cold. Check by feeling the 2 brass pipes located to the left and above the drivers left ankle...use a torch or good light - they should be stone cold with the engine running and aircon on. If hot it's probable that the arm and clip which controls the tap is disconnected.
Anyways, check that first.
And welcome to the forum.
