Fonzie
Just lost the game.
I've recently purchased some VT brake calipers, discs and pads to do an upgrade on my bog stock VS brakes, and It's been recommended to upgrade the MC too. Incidentally, Philthy has a 1" VT MC lying around that I'm pinching.
Could someone give me a walk through of how to swap it over? Or if not, anything in particular to avoid doing?
My assumption is undo the side bolts, drain the fluid. Undo the bolts holding it onto the booster (and i have a feeling there's one on the wheel arch too), slide it off. Bolt the new one on in reverse steps, fill up with brake fluid, and spend eighteen hours bleeding the damn brakes. How far off am I?
Cheers, Fonzie.
Cheers, Fonzie.
